20 years old and STILL high tech expensive
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 20 years old and STILL high tech expensive
    Posted: 11 Mar 2019 at 10:20am
My old '99 SD F250 laid down on me last Friday, renters cows got out and they were out of the area as I called them, so the wife and I got them BACK onto the farm pasture. Had my pickup in the mess as they come like a dinner bell to a Ford Diesel. Had to put it into 4Lo to keep from spinning so easily on the greasy mess so I walked to drive cows had the wife pull the truck around. Went to shift back to 2wd, no go, tried everything and then start troubleshooting. Man What was bad of floor mount shifters? Get the drive motor down, works fine, swap to known good relays, nothing, start looking for snagged harnesses, nothing there either. Finally get on the net find there is a little device called a GEM(General Electronics Module) drives this stuff, does ALL the electronic controls on the truck, then find out is bolted to the TOP of the fuse block.
What a PITA! Get it all out where I can read the FOMOCO Engineering number on it and see the build date was 4/15/99, almost a full twenty years. Ford still has them, some aftermarket refurb shops too, in any case gonna be $500 for the module EXCHANGE.
Again, WTH was wrong with a floor mount shifter?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:27am
 1, reliable. 2, not enough money involved for parts at failure time. 3, planned obsolescence.
Edited by chaskaduo - 11 Mar 2019 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 11:35am
GM seems to have made the same thing about mechanical shifting
Neighbors 2000 Chev would not shift into 4 WD - dealer repair $850
Friend who owned a transmission shop tested mine when it would not shift right ,
 $40 for new dash switch , said his sons did the same thing - dealer estimate was the same $800 - so he had dad do it for the $40 also for the switch .
 Made in Mexico switches didn't hold up but the repair made dealerships a lot of $$$
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 11:59am
A twenty year old truck is new in my book. At least the technology to keep it going. I have a GM and like Coke I’ve had lots of trouble with cheap made 4x4 switches.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 12:04pm
Got a 98 explorer, does same shift when it wants to thing. new dash switch, worked twice, back to same old no shift crap. friend says trans shift motor sticking, well I don't use stupid switch anymore, leave it in "auto mode" and mash the gas harder to go off road. It still gets me in and out without getting stuck!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 12:20pm
My GMC Sierra is about 17 years old.  "Auto" is sure a nice feature when it works....now days, Auto is the same as 4 Hi now, no auto about it, it's just "on".
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 12:50pm
Go get a Ram. Got a '16 2500 Tradesman with the 6.4 hemi and it has a floor shifter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 1:11pm
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 6:25pm
Hadda '94 chebbie s10 that had same problem, turned out to be vacuum actuated dashpot shift motor.  Where'd they mount it?  Under the damn battery box, so's all excess acid would land on it...Wink
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 6:56pm
Did you check Ebay? Or just Google the part and click the "Shopping" link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 7:16pm
The  problem  with mechanical linkages is they usually only work for ONE line of vehicles and everyone's making stuff 'universal' so really 'one size fits all'. The problem with 'fly by wire' tech is twofold. One, switches fail(well cheap ones do) and two, some kind of 'computer' needs to control 'stuff'.
Now 'one' is easy to fix...just  use high quality switches. Cost maybe $2 each, some I have used over 1,000,000 presses. Numbe rtwo s a tad harder...just ask an avioncs tech about the 737Max8 problem.
Orangeinwisco View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeinwisco Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 7:42pm
My 04 F350 has a floor shift. Love it. Google " brown wire mod". Was for an explorer, but might still apply to all electronic shift 4x4.
