Gas Tank Issue
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Gas Tank Issue
    Posted: 11 Mar 2019 at 6:09am
So I have a gas tank off an industrial that has the horizontal tube along the bottom inside of the tank to the center for fuel flow. This tank has been sitting for quite some time so I have been trying clean it out. There is a clot or something in the middle of the tube that I can break loose. I have triee, forcing air, water, wire etc in there both directions. I've been shooting carb cleaner down the tube everytime I pass by it hoping it will break loose and open up sooner or later. You guys have any other ideas on how to get the tube opened up?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 6:28am
Maybe fill tank to above the tube with pure Acetone and let sit overnight ?
If it's 'varnish', Acetone will soften it up ,over time so you gotta have patience.
I'm assuming there's no easy way to remove the tube ?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 7:06am
Tube is attached as part of the tank. And it's inside. I can shoot a picture later today if you all want to see what I'm up against.
I even used a left over piece of 6 gauge ground wire from a job to try to ram it loose. Not budging.
Edited by AJ - 11 Mar 2019 at 7:07am
Can't fix stupid
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 7:39am
Maybe a small piece of flexible cable in a drill would get up in the tube and work the plug loose?On my 460 Long that has something similar I finally just drilled a hole straight
thru the outlet hole in the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 8:36am
hmm how about a piece of 'piano wire', hooby shop sells them for RC planes... I'd get one say 1/4 D of the hole, grind a taper to the end ( "D" shaped , chiesl profile).
That should go through, if not, put vice grips on wire and tap with small hammer.
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:19am
Drop it off at a radiator shop and have them boil it out????
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 3:38pm
Not sure if you can get to this tube from the outside bottom of the tank, but if you can, how bout' a drill bit in a drill a few sizes smaller than the tube size and run the drill up the tube real slow to clean the blockage.  Just an idea.....
Steve@B&B
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 4:55pm
The angle to work with on this tube is ridiculous. I have removed the gauge to try another angle still not getting anything through. Drill bit will not work for this situation. Needs to be long, flexible, yet rigid enough to apply forcefull pressure on whatever is in there.
Thinking of filling the bottom with acetone over night like suggested and see what happens. Couldn't hurt, just make the tank that much cleaner.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 5:43pm
Try a piece of electrician's fish tape, chucked in a cordless drill.  You can sharpen the end, into a drill bit shape...  Interesting conundrum, when you get it clear, let us know what it was...Wink
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 6:10pm
Could you put a flexible pincher small part retriever thing in a drill? They are just a long  spring. Small ones are pretty flexible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 7:23pm
you could try to rig up an 'IV drip' to trickle the Acetone through the tube. I 'see' a can with acetone on the workbench with some hose running to the gas tank outlet. The idea is that gravity will pull the acetone to the tube and it'll 'eat' away or soften the blockage. Could be a slow process, overnight or longer.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:50pm
I set the tank up for the night and dumped a gallon of acetone in it. We see what tomorrow evening brings.
(Yes I closed the tank up so it won't evaporate)
Can't fix stupid
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 11:01pm
Get a piece of an old speedometer cable chucke it up in a drill and spin away
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2019 at 11:41am
Acetone evaporates pretty fast even if you mix in a mineral spirits type solvent. So keep an eye on it, also keep in a well ventilated area.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2019 at 10:03pm
Success! Acetone worked very well. She is open and flowing and clean.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 6:29am
NICE !! I assumed the blockage was 'varnish'. Dried up gas residue. Acetone slowly dissolves it back into liquid.
Be sure to rinse tank out with clean acetone/ brake cleaner AND clean out the gasline as well ! It probably has a layer of 'varnish' on the inside as well.....
Jay
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 7:45am
Yep that's what it was plugged up with. I shot a half a can through the tube to be sure it was clear and flowing well then flushed it with a couple gallons of gas.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 8:09am
The Walter Huston Treasure Dance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 8:51am
[TUBE]3w4B7QxL_n4[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 9:05am
That'd be it. Tongue
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 11:34am
AJ it sounds like you will not need a gal of gas and a match to clean it out. You might tell Randy you didn't try the big bang cleaning idea he talked to you about.WinkNuke
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 6:46pm
For those of you who haven't ever looked down in the tank of industrials here's that tube I was dealing with on the clog.
Don, I decided that Randy's idea wouldn't help me get my tank situation figured out. I would just have to find another tank if I went that route. I told him I need him to show me the correct way to do it anyway. He's yet to show me...lol
Can't fix stupid
