WD crackshaft end thrust
savedallis1953 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Topic: WD crackshaft end thrust
    Posted: 09 Mar 2019 at 6:06am
Could anyone tell how to adjust for end thrust in a WD? Thank you all for keeping A/C alive and well
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 6:07am
Oops Crankshaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 8:12am
Check with Don(MO) I believe he has some possible tips. I am sure there are other folks too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 8:15am
Nonadjustable, replace thrust bearing.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 9:40am
Thanks for the information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 9:57am
Hi Mack could you tell me where the thrust bearing is, I believe I did know but that was about 20 years ago. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 10:28am
Front main bearing is the thrust.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 5:48pm
I send mine out to be machined to fit the new thrust bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 6:14pm
Yes Thank you for jogging my memory. I am now on #7 in the W series and never really got into the bottom of these beautiful powerful engines. Building a shop almost exclusively for my small collection. I have found no other engine like it which turns 1400 rpms and makes 29 pure horses
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 6:18pm
I recently purchased the desired combination of a WD block with a WD-45 crankshaft and big valves, dished pistons + marvel schebler 871 carb with a 4 bolt wide front end.
