720 Ringear question
720g View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 720g Quote  Post ReplyReply Direct Link To This Post Topic: 720 Ringear question
    Posted: 08 Mar 2019 at 11:28am
I have a 720 that could use a different ring gear. I know that they use a ten tooth starter, I have a new 9 tooth starter that that I got that was supposed to be a 10(Don't ask long story) can I get a ring gear for that starter? I was told that other applications went that way for faster starting. Any thoughts or ideas.. Thanks in advance John
I don't post much but I read the forums everyday, not only great info but some great entertainment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 4:30pm
All the 620/720's that I've encountered were 9 tooth. Some of the 10 tooth versions according to some of my applicaition books + the internet were used in other Onan models, or used with the CCKA version of the Onan. I have a brand new 10 tooth on the shelf if your looking for the 10 tooth.
Steve@B&B
720g View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 720g Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 7:03pm
Thanks Steve I've got the original one needs some work but I've got a guy who can rebuild it. I got a new starter and it was wrong. I probably changed the numbers in my original post. I'll have to double check. Thanks for the reply. By the way that new harness works great was well worth the money.
720g View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 720g Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 7:16pm
Do your books show what might use the 10 tooth starter? My 10 tooth starter is brand new just wondering if a ring gear for that might be available to fit the cckb. Either way I need to get a different ring gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 10:27pm
Glad you like the harness John! I'd give Brenda a call at Sandy Lake tomorrow and see if she can hook you up with a new ring gear. Not sure if they're available yet. Ya never know tho. She pulls a rabbit out of her hat sometimes. She's the best!
Steve@B&B
720g View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 720g Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2019 at 7:40am
Thanks Steve they are not available new anymore. I talked to her already they might have a used one.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:51am
CHECK ON E-BAY UNDER ONAN CCKB.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
720g View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 720g Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 9:14pm
Thanks will do..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2019 at 10:08pm
John,
I have a 620 parts Tractor. It has the engine in it. Couldn't tell you what condition of the flywheel ring gear is in, but unfortunately, I wouldn't be able to get to it cause its buried in the snow under a tarp at the present time. Probably wouldn't be able to get to look at it till Spring. I guess it doesn't do you any good right now, but I have a possibility....
Steve@B&B
720g View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 720g Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2019 at 6:31pm
Thanks Steve, I've got a old Simplicity dealer out here who is doing the same he has several engines to look at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 6:47am
That's a good thing!  Maybe he can come up with somethin' for ya. Good luck!
This page was generated in 0.294 seconds.
