wd 45 no start
trace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 no start
    Posted: 04 Mar 2019 at 11:57am
just used this tractor ten days ago. 1955 wd45. tried to start last friday and nothing, no sound or anything. battery good on tender, new starter two years ago, ignition rewired two years ago. thinking culprit may be the starter switch. any suggestions?? too cold to work on it right now but going to be nicer the end of the week.
1955 WD-45 WIDE FRONT W/ TRIP
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 12:30pm
Got a multi-meter, or a volt meter?  6v or 12v system?
Start right at the battery and check that you have voltage down stream all the way to the starter.
Diesel of gas?  I'm guessing it's a key starter and not the rod pull type?  If it's a key start, do you have voltage coming INTO the switch?  Coming OUT of the switch?  Voltage AT the starter?
We need more info.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 12:32pm
Don’t rule out the ground side of the circuit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 3:32pm
Well, if you know the Battery passes a draw test then your guess about the mechanical starting switch could be a possibility. Check your cables for good connections and make sure the ground cable is clean and making a good ground. The bitter cold weather plays havoc with electrical connections and operation.
Steve@B&B
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 3:57pm
Go through and check all the wire connections and see if one is loose. Check the ground cable on the battery for corrosion.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 4:08pm
if it has the mechanical switch take off switch take off starter hold cable right on stud on starter it turns over starter is ok
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 7:50am
thanks for the suggestions guys. will use your advice towards end of the week when weather better. been a cold and windy mess here lately and more coming saturday, thanks.
LOADER
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 8:54am
On the mech. switches, the contact plates get worn/dirty and lose contact. I have 1 that went bad and I took it off and hit the post with cable and it started. Had to put a new switch on that one. If you have to get new switch, be sure to get the right one! There are 2 different ones and they are not interchangeable . thanks; ac fleet
