Replacing detent balls and springs in D17 trans
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Replacing detent balls and springs in D17 trans
    Posted: 02 Mar 2019 at 1:50pm
Just wondering about what is the best way to replace these"little buggars"?
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 2:15pm
I have no D17 knowledge but....
buy 5 as 4 will drop into the bottomless pit of oil...
when you're at the store the 2nd time, buy a magnet on stick to get the 'missing' balls
Wink not that that has ever happened to me...
be SURE to account for ALL the balls or one WLL go crrrrrunch...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 2:21pm
Yes, and wear safety glasses so one does not lodge in an eye
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 7:55pm
Use a old rail or shaft same size as rail. Grind a U grove in one end. Push tool under ball and spring, rotate tool 1/2 turn. Push tool out with rail.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2019 at 2:18pm
I got it done.  Thanks for your comments.
This page was generated in 0.079 seconds.
