Cracked filler neck on a fuel tank
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Cracked filler neck on a fuel tank
    Posted: 29 Jul 2010 at 6:50pm
Hi
I have a fuel tank that the filler neck has broken loose from the tank about 180 degrees around its perimeter.
What is the process or procedure to fix this?
Fill tank with water?
Use acetalyne torch to heat the lead (??) to get it to flow and reform?
Completely remove...clean both pcs and get some new lead (??) and weld it back on?
Let me know your thoughts.  Thanks in advance for the help.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 7:23pm
  Drain fuel, remove from tractor , clean tank,  remove neck from tank , clean and re-tin neck and tank where neck mounts, re-solder neck to tank, clean repaired area, refinish to suit. Have a cold one.
