Freeman Loader phone #
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Topic: Freeman Loader phone #
    Posted: 29 Jul 2010 at 11:35am
Does anyone have a phone number for the Freeman Loader Co. in Yankton S.D.?
I am needing a cylinder seal. Thanks. Jim
ernie (ECIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ernie (ECIN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 11:59am
Here you go: (taken straight from google.com)
The Freeman Co.
Address: 719 Walnut St.
Yankton, SD,
57078-0057
Business Activity: Manufacturer / Exporter
Phone: 605-665-7456
Toll Free: 800-843-6807
Fax: 605-665-7882
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 12:02pm
Well that explains why I didn't find them via google--it's manufacturing instead of loader. Thanks again.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 3:03pm
I bought seals for a Freeman Loader for a CA from Sandy Lake Implement. Were in stock.
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 5:34pm
I bought my seals from a local hydraulic shop for $10.00. Just a suggestion.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2010 at 10:36pm
Thanks for the number and ideas. My neighbor told me exactly where to go here in OKC and that they probably would walk back and pull it/them off of the shelf.
Now my next challenge is getting the bottom to unscrew in order to pull out the piston to install a new seal on it.
Is there a tool somewhere to do this with? I made a pipe tool with 2 prongs on it to unscrew it, but it's pretty tight in there and wouldn't budge. As far as I know, these are the original packing leathers and never did know or see dad fix this leak.
Thanks again for any and all info and ideas. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 7:46am
Jim, there is no piston. The cylinders are displacement cylinders and only have a snap ring on the back of the rod. Take the gland off with the rod and remove the snap ring. Pull the rod out of the gland and remove and replace the chevron packings. If the bronze guide bushing is worn enough to let the rod slop around, it needs replaced too. Do not over tighten the packings. They need to weep a small amount of oil to lubricate the packings.
