Go Big or Go Home!
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Topic: Go Big or Go Home!
    Posted: 20 Feb 2019 at 7:09pm
My biggest bowl to date.  I like it!  Blank was 6-3/4" layers thick by 11" across.
Greg Kroeker
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2019 at 7:56pm
 That rught there is one heck of an art talent you got there, Omaha,,,,Beautiful work for sure,,,,Now you just got to hook with ole Tom over to Iowa to set you up with one of their choice booths,,,,Clap Be no problem selling them bowls,,,,ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2019 at 8:29pm
Those are some nice bowls!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 12:55am
Greg if you are interested, there is a big craft show. If you Google Callahan Craft shows. You will find it. Dad gum it, it is in the town east of Omaha. This getting old and forgeting the name of the town sucks. There are other fellows that spend their winter's making things like you have and then making the circuit selling them.. you might come to the show and check things out. In the mean time it's looking good.
Edited by HD6GTOM - 21 Feb 2019 at 12:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 7:32am
that town is called: Council Bluffs!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 1:46pm
Looks great Greg
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 8:12pm
Cool bowl!
So Greg... what does your blank look like BEFORE you turn it?  You glue a bunch of blocks together to make the blank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 8:36pm
I cut and glue up the pie shape times 6-using a strap clamp.  After the glue is set I sand both surfaces flat on my bench top belt sander.  I then drill for the dowel in the center-helps with orientation and cosmetics!  I then glue up the 6 blanks into this!  Once dry I cut the blank from the bottom at 22.5 degrees before chucking it on the lathe-helps establish the shape.  I figure I have 4 to 5 hours in prepping the blank and 1.5 hours in the actual turning/sanding/sealing!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2019 at 6:34pm
Wow... that's cool... a whole lotta chips on the floor.  Must be really good glue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2019 at 8:49pm
Titebond II glue is great!
Greg Kroeker
