426 block heater |
BKarpel
Joined: 27 Apr 2012 Location: Collinsville IL Points: 115 |
Topic: 426 block heaterPosted: 06 Feb 2019 at 7:05pm |
I am wanting to put a block heater on a 210. Does anyone make a screw in for the plug in the block? I haven't tried AGCO. If I use tank style heater where would I plumb the in and out lines? This tractor has a coolant filter and original engine.
Edited by BKarpel - 06 Feb 2019 at 7:06pm |
Jim.ME
Posted: 06 Feb 2019 at 8:15pm |
AGCO parts books show one # 70256703. Phillips Zerostart # 3500013 may fit.
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Posted: 06 Feb 2019 at 9:51pm |
Factory heater goes in the rear of the oil cooler. I would thing a factory unit would cost less then the plumbing for a tank heater.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 07 Feb 2019 at 3:28pm |
[QUOTE=wekracer] Factory heater goes in the rear of the oil cooler. I would thing a factory unit would cost less then the plumbing for a tank heater. [/QUOTE
Are you talking the cooler on a 210 or 7-8000 series.Agree on later units but no so sure on the old 3500's. |
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1580 |
Posted: 07 Feb 2019 at 5:22pm |
They go in the same spot.
JimWenigOH
Posted: 07 Feb 2019 at 7:20pm |
This is what I installed on my 220. It is 1" pipe thread hole to rear of oil filters.
Edited by JimWenigOH - 07 Feb 2019 at 7:21pm |
BKarpel
Posted: 07 Feb 2019 at 10:31pm |
Thanks for the picture Jim. That is where I thought one would go. Will try getting the plug out or install a tank style if it doesn't budge. Earlier 426 blocks dont have a big tube style oil cooler.
Edited by BKarpel - 07 Feb 2019 at 10:31pm |
JimWenigOH
Posted: 08 Feb 2019 at 9:02pm |
The heater is a Kat's 11407, 1" NPT, 400W. Works good. I didn't want the long cord that came with the heater hanging on the tractor so I bought a 12" cord, Kat's 28206. The heater can be bought on eBay for under $40.
JimWenigOH
Posted: 08 Feb 2019 at 9:45pm |
This is the 600W heater I removed when I installed the plug heater, just another option.
Edited by JimWenigOH - 10 Feb 2019 at 2:25pm |
JimWenigOH
Posted: 08 Feb 2019 at 9:48pm |
On the tractor.
wekracer
Posted: 09 Feb 2019 at 6:11am |
I wouldn’t think that would work very well. If the thermostat is closed It would have a hard time circulating.
DrAllis
Posted: 09 Feb 2019 at 6:53am |
Years ago, I saw lots of those lower hose type heaters on AC tractors. Were they as powerful as a 1500 watt tank type heater ?? Nope. But they were easy to install and certainly were better than a dipstick heater or an oil pan magnet type heater. Try and install a tank heater on a D17 or WD45 gas engine. A lower hose heater is a piece of cake.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 09 Feb 2019 at 7:15am |
If I could at all make a block heater work I’d take it over a tank heater any day.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5205 |
Posted: 09 Feb 2019 at 1:58pm |
The bypass hose will allow enough to circulate.
PDehring
Joined: 06 Jun 2018 Location: Central MI Points: 106 |
Posted: 25 Nov 2019 at 6:58pm |
I see in Kats' catalog, they list a 1500W for the 3500/220. How long does it normally take to warm the block with the 400W?
JimWenigOH
Posted: 25 Nov 2019 at 7:56pm |
I usually plug it in at least an hour or so prior to starting the tractor. Tractor is always in a barn when not in use.
NEVER green
Posted: 26 Nov 2019 at 9:02am |
I used the 1500 watt on both our 8050's will start at 20 bellow pretty easy! |
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
JimWenigOH
Posted: 26 Nov 2019 at 4:54pm |
The Kats 1500 watt P/N 30207 that is listed on their application chart was too long to fit into my 220, that's why I went with their 400 watt P/N 11407. Double check me by removing your 1" plug and measure your maximum insertion depth.
Albert
Posted: 26 Nov 2019 at 6:43pm |
70256703 no longer serviced by AGCO
Albert |
PDehring
Posted: 27 Nov 2019 at 11:47am |
Ok, perfect, that's what I needed to know. I'll check when I pull the plug but I'll stick with the 400W just to be on the safe side. I still need to get another heater for a 3400 engine. Thank you sir.
Edited by PDehring - 27 Nov 2019 at 11:48am |
Alvin M
Posted: 27 Nov 2019 at 3:35pm |
Kats 30207 is 3 1/4 long For The older 426 Engine Like The 210 and 220 Kats 30303 is 5 long For The Later 426 Engine Like 3500 and 670 From 7030 to 8070 You Can Use 30207 In All The 426 Engines It Is A 1500 Watt Heater
Edited by Alvin M - 27 Nov 2019 at 3:40pm |
PDehring
Posted: 14 Dec 2019 at 7:26pm |
I installed a Kats heater in a 220 earlier today. Before I did, I measured the depth of the cavity with the plug removed and it is only 2" (from the outside of the block to the back of the cavity). There is a deeper part of the cavity but it is not centered with the hole so a longer heating element will not work.
11407 is the correct part number for a 220/3500 even though Kats catalog lists the 30303.
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 529 |
Posted: 15 Dec 2019 at 6:50am |
Is there one of these heaters available for the 301 block?
