D 10 III Hydraulics timely lesson
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Topic: D 10 III Hydraulics timely lesson
    Posted: 27 Jul 2010 at 9:28pm
Brothers D 10 III developed a leak in the coupling at the valve. (line from the valve to the Rear rams).  Removed the assembly and it appeared the line was just loose, removed it with the fingers. Called our local hydraulic line shop and ask if they could pressure test it.  Answer was no. So, we  took a chance and put the lines back on.  After 6 hours of reinstalling original steel hydraulic AC lines, lost all religion, you know the story, cranked her up and leak was good as ever.
So , now it is a funny story on myself, with a question, is there a secret to easily removing and reinstalling those lines. We have to tear this down again and it is tempting to have the steel replaced with flexible lines, but I don't like the lack of originality.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 6:56am
Thanks, that was a lot of help. If you need to know how to check the oil in your car, give me a call, I will be glad to help you. 1st lesson will be how to get the hood open.
StanOhio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanOhio Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 7:15am
I have a ser 1 that the line was lose on to. Mine has a hose on it I think. Was on it when I got it. I will look at it when I go to the shop, if ya can, e-mail a pic to me cause if I remember right, mine had 3 lines coming off it. They had mid-mount stuff and who knows what. Let me know and I'll help anyway I can. Oh, I didn't like the spammers answer eather!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 7:35am
Joe, I'm almost in the same boat. My remotes work but the lift arms don't. I think the relief valve for that part of the system needs cleaning, but it's such a job to get to that I'm still thinking about it.
two0426 has been reported.
Dusty
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 8:28am
Dusty -- I don't have the book here at work.  Is there a setting on the valve system that retards the lift arms for cultivator use like the CA?  This can stop them altogether.  Also, check the traction booster valve to see if it is stuck, however this usually stops them in the up position.
Joe -- I don't know of an easier way, but look at the mating surface on the line, if it has an imperfection, dint or something, it will leak, hydraulic shop can re-crimp the end. Also check the mating face in the valve, may need reaming.
Two0246 -- In the twenty-two years I served in the Army, your particular situation only came up twice.  In each case, we had bought an defective Black Battle-strider and had to return it for a Cobra gunship.  Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 8:48am
There's a shaft coupling with a rubber shock absorber in it. The rubber was gone and the pick up screen was covered with what I thought was sludge. After I found the rubber shock absorber gone I realized what was on the pick up screen. I figure that some of the same stuff is in the relief valve.
Dusty
Jim Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Blue Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 9:43am
Joe I had the two spool valve off my 1960 and do not know how similar the series three is to it.  Not much trouble getting it off but going on was a problem.  I installed the valve to the bracket and bracket to the fender and discovered removing the seat assembly and leaving the fender bracket bolts loose I could work the valve around to line up the threads on the flared connections.  It also helped to remove one of the four bracket bolts for better wrench access when it was in the way.  Mine still leaks after new seals and hard parts are no longer available for the early valve.  Valve restoration is expensive so I am still thinking about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 11:30am
Thanks Jim, that describes basically what we did. Just time consuming to avoid cross threading.  I bet they rarely had truoble with those before allis closed. Probably not many removed and replaced except by wanta be's like me.
I have another one identcal torn down, I knew when I tore it down it would be a job to hook the lines back up. Wish could talk to our former former mechanic at our dealer, but he is in the big AC shop in the sky. I bet he was as good a WD and D series mechanic as there was.
This page was generated in 0.127 seconds.
