M Steering Clutch
PDehring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Topic: M Steering Clutch
    Posted: 03 Feb 2019 at 10:18am
I have a M crawler and when I pull back on either steering lever, nothing happens, the crawler keeps going straight.  When I pull back on the steering lever and touch the brake, it turns on a dime.
I adjusted the steering clutches per the operators manual but it didn't seem to change anything.  The left side got slightly better but not where it should be.
I haven't messed with steering clutches before so does this sound like the clutches are worn out or would cleaning them help?  Any guidance from someone who has experience with this would be much appreciated.  I don't want to take the final drives off if I don't have to.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 10:59am
Mine works the same way. With a load on the machine, pushing or pulling, when you pull back on the steering lever it will turn. With no load, needs the brake to turn.
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 3:01pm
I wondered the same thing on my HD16. However the group is right, going up hill, pushing any load and or backblading it turns fine. I was used to a smaller dozer from my past, and it turned on a dime without foot brake application. It was a John Deere 450C.
I did as you did, adjusted linkages to speck and it helped a little but touch a food brake and she turns fine.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 3:19pm
It sounds to me like everything is working normally. Darrel
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 4:38pm
Jerbob,
Now I understand your concern with how your was HD16 turning. The Hd16 and 450C steering controls are two different animals. On the HD16, and others with separate steering levers and brake pedals, the steering clutch lever releases the steering clutch and brake pedal applies the steering brake, two separate functions. The 450C, and others with combined function controls, the lever or pedal operates both the steering clutch and the brake. The steering clutch releases as the lever is first pulled. As the lever is pulled further back the brake applies. The further you pull, the harder the brake applies. Pedal steer similarly releases the clutch then the brake for steering. The 450C and others, generally have one separate brake pedal that applies both brakes together to stop/park the machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 5:57pm
You are right. I didn’t get it for quite a while based on these differences but what you say makes total sense.
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 10:05pm
Good info guys.  I didn't realize the brakes were needed to steer with no load.  I always assumed the steering lever was a single function (i.e. pull the lever back and it turned).
