Electric motor experts
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Electric motor experts
    Posted: 02 Feb 2019 at 4:58pm
I’m working on the old drillpress I bought. The motor starts slow and doesn’t have much power when it’s up to speed. It has a 2 wire romax with white black and bare ground. That makes me assume it’s hooked for 120 but the motor is big for a 120 v motor. I’m thinking it should be on 240 but it doesn’t have a tag for wiring. Should I just find another motor?
The switch is in a good size metal box. Push buttons. It has a breaker that will trip and reset after a couple minutes. It won’t run 30 seconds without tripping even with the belt off. It has a capacitor but I don’t know if it’s a run or start capacitor??
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 5:35pm
Would be odd if it were 230volt.  Was the motor sitting out where mud daubers could get in it.  Bad capacitor or mud dauber in the end of the motor will cause the breaker to trip as you describe.  Sounds like its not getting off the start winding's.   Start capacitors are normally black hard plastic material, round, and have numbers on the side with a range like 189-225mfd, followed by the numbers 110vac or 330vac, which by the way DOES NOT have any relation with incoming voltage.  Run capacitors will have a fixed MFD rating like 5, 10, 15 etc..  If you have an ohm meter you can give the capacitor a quick check.  I can give you instructions if you want.
There is a centrifugal switch in the end of the motor, once the start capacitor nudged it up to speed, the centrifugal switch shuts off the capacitor and the amp draw drops dramatically.  A mud dauber nest will prevent the switch from moving and
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 5:41pm
I do have an ohm meter and would like instructions to check the capacitor. I’ll look at tha capacitor and see what it is in a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 5:59pm
This test won't give the MFD rating but will check if it's open or shorted.
First unplug the drill press.
Remove the cover with the capacitor.
Don't touch the terminals on the capacitor until you first short them together with a screwdriver.  If you do get a spark you don't need to go any further, the capacitor is good.
If you don't get a spark it doesn't mean it is bad though.
Remove the wires from the terminals on the capacitor, if there is only one wire on each terminal don't worry about which came from where, if there are two wires on one side mark those so they go back together when you reinstall.
An analog ohm meter works best but a digital will work also, just have to look quick.
Set the meter to something above the lowest setting but not the highest.
Touch each terminal with one probe, (red lead on the left terminal, black lead on the right), at the same time, probably no activity on the meter this time.
Now swap the leads, (black lead on the left terminal and red on the right) while looking at the meter display.  An analog meter, the needle will go up a ways and back to zero.  A digital meter will go up in number and return to infinity.  If the meter goes up but fails to zero the cap is bad.  If the meter does not go up, reverse the leads and check again, if the meter fails to go up then the capacitor is open and bad.
You can check it as many times as you want, just keep reversing the leads.
I'm not a motor expert but people have paid me thinking I am.LOL
Edited by JW in MO - 02 Feb 2019 at 6:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 6:27pm
NEVER ever ASSUME what voltage it IS by the wiring. Idiot 'electricians' and 'HVAC pros' WILL and DO wire 240 with NMD-2 ( black and white). sigh, to me it should be NMD-3 where black and red are used for power. I've also seen 240 on regular 120 receptacles, that's 'fun'.
I'd get rid of the motor and use one you KNOW is good. What's your time worth? $50 /hr..waste 2 hrs and you could have bought a new motor ! Life is way to short and get shorter the longer we live.... unless you LOVE a challenge, swap it out for a good motor.
Jay
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 8:02pm
How well the motor turn by hand when not turned? Perhaps the bearings are dry or gummed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 8:03pm
Ok guys I went to the shop and started cleaning that motor up and found a tag on the end cap. It said 1/2 go 1725 rpm and 208-220voltage. I hooked it to 220 and it runs like a top.
JW I plan to keep your instructions for further use. I appreciate the lesson very much.
This old drillpress is the quietest smoothest running drill I’ve ever heard and it is tight and has very little runout. That motor is quite large for a 1/2 hp it’s made by Emerson.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 8:15pm
Should be wireing digram in motor cover.On 220 voltage neutral carries no power. Might explain bare wire.At work found 3 green wires carying 440 in conduct.That makes it interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 9:58pm
Probably large and heavy since it is an INDUSTRIAL motor... the 208 volts single phase is standard in a factory that runs 480v 3 phase power.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2019 at 10:02pm
  There you go,,Thad,,,with just a little more work,,,you gots you the makins of a nice mill,,,,yeah,,!!!!
  Thas the main reason I'm lookin for a floor mount drill press to UMMmm,,,,, modify as a small mill,,,,,???  I doubt I'll ever come across a mill I can afford so I'm gonna amke one,,,,,Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2019 at 6:53am
Joe I still have that Atlas that I recently got. I cleaned it all up and put a 1 hp motor on it.
It has a bit of runout. Not sure of bearings will fix it or not. Supposedly Atlas has 4 bearings in the head and might be well suited for a small mill table.
It has a vibration but I believe it’s the crusty old belt I found hanging on my shop wall to try it out.
The chuck is very nice on that Atlas but not Morse taper.
