D15 gas narrow front 3 bottom plows 3pt adapter
Hardrock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardrock Quote  Post ReplyReply Direct Link To This Post Topic: D15 gas narrow front 3 bottom plows 3pt adapter
    Posted: 24 Jan 2019 at 2:34pm
This tractor is a 1964 model, best I can determine. I've had it about 30 years. Engine rebuilt 3 or 4 years ago but still having trouble....it was losing power and dying under load (six foot finish mower or plowing/disking. Now won't start at all (I replaced condenser, points, regulator, coil) and may have gotten the distributor out of position.
I just bought another tractor and now trying to decide if it's worth it to try to get the AC running or maybe even try to get to show quality. If I sell it as is (not running) what is it worth? Are the plows/adapter for the snap coupling worth anything at all? Tractor is near Louisville, KY.
Thanks for any advice.
waldersha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldersha Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 2:48pm
Around here in Kansas the adapter would be worth probably $300, the plow maybe $175 at best.  Tractor not running depends on the year/condition of everything else, but probably $1,500 tops.
There isn't all that much to them, it would be worth trying to get it going again.  Setting the distributor right if it is off isn't hard.
Start with the easy things, is it getting fuel to the carb and spark through to the plugs?  Let us know what it's doing and there are tons of knowledgeable people to help you out here.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 5:40pm
You did work on the electrical but you made no mention of the fuel system.  A carb full of crud can cause a loss of power and dying under load.  Clean out the carb, fuel tank and sediment bowl screen and refill tank with FRESH gas.  After that, time the engine with a timing light.  If the plugs are good, she should run fine after that.  There is nothing majorly wrong with the tractor and these steps do not cost a lot.  In my opinion this is maintenance that should be done after 50 years of use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 5:55pm
Sounds like it turns over with the starter correct?
You might want to have the compression checked?
If they have gas and spark and some compression and timing is close, they should run. Maybe not run well but should run.
I suggested the compression check because it sounds like it gradually ran out of power over time?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 6:07pm
I bought a WF once that the seller said the tractor just started running worse and worse
finally wouldn't start.I pulled the valve cover the rocker assembly had worked loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 6:12pm
Yes I think Gary might be on to something too!
Good luck with your tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardrock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 6:14pm
Ooops. My bad. Carb rebuilt. Bowl cleaned. Flow to carb confirmed. Tank totally removed and cleaned. Thanks for the reminder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardrock Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 6:17pm
All I can say about compression is the company that worked on it SAID they put new rings in it and tested it. It ran fine for 2-3 years after the engine work. Thanks.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 6:47pm
This happened to me once.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 8:34pm
Couple of thoughts.....
My WC ran poorly - and got worse and worse - because the air cleaner was plugged. Must have been nearly solid when I got the tractor and just got worse. Cleaned it and it was like a new engine!
Also....on the electrical parts you replaced - my experience with replacement parts (especially condensers) for my antique cars is that brand new parts are sometimes junk out of the box. Have you checked to make sure that you have a good hot spark at the plugs?
WC, CA, D14, WD45
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 7:04am
Is it a series 2, do you have pictures, I am near Owensboro and maybe looking for a D-15 series 2 in the spring if I get some room in the shed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardrock Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 2:38pm
I think it must be series one....I can't find a SN but it has the head lights up front and the decal also indicates S1.
I'll just use the new tractor to pull it in the new barn where the newly retired old guy (me) will learn the finer points of tractor mechanics...or not....at least I'll be out from under foot in the house. The master plan is finally coming together!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardrock Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 3:06pm
I think I found the serial number. Stamped on the left side I found "15 4509". I think that would make it a 1961 model. It has power steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 4:38pm
Hardrock,
 New tractor, New barn, retirement! Congratulations! Yes this tractor will help keep you out of trouble!
 Chrris
