Turning a 426 AC engine to 466 ci ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Turning a 426 AC engine to 466 ci ?
    Posted: 22 Jan 2019 at 4:31pm
Curious on what sleeves and piston need to be used after matching the block on a 426 to make it 466 cubic inches?
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 5:16pm
Easiest would be custom sleeves and pistons. Will hold up better than cast iron sleeves and stock pistons because of better material.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 8:22pm
You will not need to bore the block to get 466ci just a 4.450 bore and find a piston close to that or custom piston
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 4:26am
I Gottcha thanks for the replys
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 6:57pm
We use cummins pistons with allis rods reworked to fit and a custom sleeve. Puts it a bit past 470ci
