200 seat
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 200 seat
    Posted: 20 Jan 2019 at 7:15am
What seat did the 200's have on them the 3 piece seat or the black seat with the flip up arms. Where the best place to get one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:27am
They used two different black seats. What age or serial number is the tractor ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 11:33am
It's a 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 12:17pm
Tractor Supply has got some nice ones
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 1:38pm
My late one has the black seat with the flip ups.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 6:23pm
My '75 has the black with flip up arm rests.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 8:44pm
How much do you want to spend. A fellow forum member tipped me off to a seat that's made for logging equipment and is almost identical to the original
JWV Fulton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWV Fulton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 9:09am
Go to www.tractorseats.com and you should find what you need.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 1:03pm
They have a lot of nice seats that are a lot like the original, but not quite...
Edited by WF owner - 22 Jan 2019 at 1:05pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 11:09pm
IF memory is good today; the early black seats are the ones where the arm rests attach to a stud sticking out each side of the back rest. Later seats have a bracket for the arm rests that bolts (using 2 of 5/16" bolts) to the irons coming up to hold back rest.
Arm rests are the same for both seats. AGCO has them in the Heritage Parts catalog.
Backs n seats are available thru most ( several on this site) vendors dealing in seats. If you need to redo the suspension DJ's has most of what you need, have the lever/arm now, also the pins and bushings, the 4 plastic wheels for the slide are getting hard to find.
dansig1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dansig1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 10:08am
Can you tell me where I can get this seat and how much? Thanks. I'm referring to Mikez post.
Edited by dansig1 - 21 Feb 2019 at 10:09am
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2019 at 4:45pm
Dansig1,
Serco Loaders, a supplier of forestry industry equipment, uses the seats on their loaders. Their dealers carry replacement seats. Check the Internet for your nearest dealer for availability/price. I purchased a seat for my 1975 185 several years ago. As far as I'm concerned, the seat is an exact match to the factory issue from Allis Chalmers in appearance, quality, dimensions and comfort etc. Milsco (Milwaukee Seat Co) supplies the seat to Serco, and AC back in the mid/late 1970's.
Pictures, discussion, more information etc are available in an earlier thread started by Forum Member MikeZ on April 21, 2017, title Seat in 200
Good luck with your project
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 7:12pm
I just got an email from DJ's and they have this seat. I'm sure it's not the same as original, but that's what the are listing for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dansig1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2019 at 3:07pm
Thanks for the replies! Now I am wondering if a 200 seat will bolt onto a 190xt suspension or do I need to get the 200 suspension? Will the 200 suspension bolt to the 190xt fuel tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2019 at 6:20pm
Dansig1
From the online AGCO Parts Book the 190 (page 192) and 200 (page 132) have common seat assembly support connections to the fuel tank for older serial number tractors (part no 70241895 - seat support).  Later serial no 200 tractors (page 134) had a newer seat assembly setup.  The assembly shown on page 134 for the 200 is what is required to support the Milsco seat noted in my earlier post.
The year/serial no of your 200 should help you determine what seat will fit your tractor.
Also, based on the common part/attachment to the fuel tank for the seat assembly for the older 190/200 models noted above, there is probably a way you can mount the Milsco seat on a 190 with a few seat support/suspension components from a donor 200.
Hope this helps
This page was generated in 0.168 seconds.
