720 Allis Chalmers |
Mike K
Joined: 27 Sep 2009 Location: Edgar, WI Points: 231 |
Topic: 720 Allis ChalmersPosted: 19 Jan 2019 at 11:47am |
I am about to change fluid in my 720. I need to locate the drain plug for the hdy. I have the filter. How much fluid do I need to have to replace it with, and the correct type
Thanks Mike
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4257 |
Posted: 19 Jan 2019 at 1:14pm |
I'll be watching this. Bought the filter to change mine last summer, never found the plug!
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5412 |
Posted: 19 Jan 2019 at 2:09pm |
There is no true drain plug. Remove the transmission temp sensor located in the lower front of the hydro. Bottom pan has to be removed if it hasn’t already removed. Lots of dirt, mice nests typically there. Fluid amount and type is located on the sticker located under the hood. Easy job.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2590 |
Posted: 19 Jan 2019 at 2:17pm |
see post is garden section
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
