Popping Gears
PDehring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Topic: Popping Gears
    Posted: 19 Jan 2019 at 11:50am
I've seen a fair share of tractors for sale where the seller will say pops out of 3rd or 4th, etc.  What causes the shifter to pop out of gear?  Does it happen pulling a load, no load, going downhill, etc?  I've also seen comments were its just the detent or a bent shifter fork.
If I was test driving a tractor, what would I need to do/look for to see if it has any gears that pop out during operation?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 12:09pm
Grinding the gears when putting it in gear is the biggest cause.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 12:25pm
Worn shift collars due to grinding gears in the past.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 12:34pm
Snap the power director back into low going down a hill or pull the throttle way back. Just be ready on the brakes if it does jump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 3:46pm
It a lot of operator eror as in grinding gears,, but I think Allis should have changed the design as the production ran for years and had this problem for years
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 4:26pm
Thanks, that makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 9:43pm
A transmission brake would have fixed a lot of problems.       MACK
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 10:57pm
Exactly. Its absence kept the price down though.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 5:59am
A bit of advice. If the seller tells you, or you find by test driving the tractor, that it jumps out of gear, don't buy it unless you plan to invest (a ball park figure of) $2000 to repair it.
You might get lucky and it is something inexpensive, but be prepared for the worst. If it needs new transmission parts, they are expensive and installing them is a pretty big job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 10:55am
Thanks, that's what I was thinking as well.  I want to stay away from any transmission issues.  Even if the tractor was priced accordingly, there is still the parts and labor of making it right which is something I'm not looking to tackle right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 1:07pm
Honestly if your looking at a ONE HUNDRED SERIES ALLIS just plan on it jumping out of gear ,, every one does eventually
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 1:44pm
Did they fix it on the 200 series?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 2:23pm
I’ve had 4 and none of them jumped gears. Have a D17 that jumps out of high range when cold , and a 7060 that used to jump 4th before I fixed it. Treat them right and they won’t jump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 4:43pm
Sorry, but I don't agree with that statement at all !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 5:40pm
Just experience with these and an opinion as some 200,s jumped out of gear new, its also some to do with bearing wear, shifter detents and the sliding gear collar all wear over time
Edited by DougG - 21 Jan 2019 at 8:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 6:52pm
I still have Dad's (1968) 180 and (1978) 185. He bought them both new and I put a lot of hours on each one. Neither jump out of gear (and the 180 has a loader on it).
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:08pm
I have a 170 that is perfect and two 200s that both jump, which according to what I have read here can be fixed by removing the top of the transmission and repairing the fork. So to the original poster it depends on which tractor you are talking about. Also have a 5040 that doesn’t jump, but I figured no one considers that a true Allis.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 7:27pm
In the mid to late 60s my brother bought a new 190 tractor. For some reason,that tractor was especially hard to shift without grinding the gears. At first,we would shut it off to put it in gear,but after awhile we learned to put it in low gear first,and then put it in the desired gear from there. The reason being that first gear is turning slower and the grinding is much less severe going into that gear. Putting it in first gear stops all the gears in the tranny,so you can then shift without grinding or clashing anything. When i bought my 175 in 1986,it had 1100 hours on it and it would slip out of third going downhill,so the damage can happen pretty quickly. My dad bought the 170 that i now own in 1972. I have always shifted that tractor as explained above,and it now has 14,000 hours on it. It does not slip out of gear. The only work ever done to the transmission was when the power director was tightened. It does not slip out of first gear either. This tractor had a loader on it too for many years,but not anymore. Some of you might think i'm full of baloney,but this works for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 8:14pm
My ‘68 XT doesn’t jump out of gear. Follow the owners manual on shifting,have some patience, and it will shift as it should without popping out going down hill. Hour meter broke at 4073 hours, who knows how many are actually on the 51’year old tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 8:16pm
Dads ‘68 D15 isn’t a gear jumper either. Bought new in ‘68.
Relayman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Relayman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 10:04am
I will tell my tale of an experience with a "gear-jumper". I bought a 1968 190XT with a locked-up foot clutch. Had to load it using only the power director which was a treat. I replaced the clutch to get it running but then found it was a bad "gear-jumper". Without deep pockets to fix it, I resorted to the tactics of a shade-tree mechanic. I welded up the 3-4 shift forks so it would just fit in the badly worn shift collar groove. This helped to keep the shift collar from "wobbling" when in gear. I then ground the 3-4 detent grooves on the shift rail so the shift fork could move as far forward and as far rearward as possible. This allowed the worn shift collar to get as much tooth engagement on the gears as possible. Plus the deeper shift rail grooves really helped to make it more difficult to jump out of gear. This tractor eventually became a farm-stock puller and we never had an issue with it jumping out of gear. I also have a 1971 190XT with 4500hrs that has never jumped out of gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 10:10am
Those are all good places to start, cheapest anyway
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 7:42am
Between myself, one of my brothers and my dad we have had only three gear jumpers in the past 50 years. All were bought with that problem already existing. A WD45 that is on the list for restoration, a D17 that my brother immediately had repaired and used it to tractor pull, and a 190 I bought and used for years for haying and that only popped out a handful of times going down a steep ditch. The working tractors that spent many years here on the farm doing all kinds of tasks that have yet to pop out of gear are a 190XT Series III Landhandler, Dad's old D17 he bought in 1973 that was run almost everyday he owned it from 1973 to 1997 when when we quit milking cows, a gas 190XT Dad bought in 1977 that did all our heavy work but now sadly sits in the pasture, well with that tractor sitting in one spot for nearly 20 years is a long story and not the tractor's fault, and my brother has another D17 that's done a lot of haying and some tractor pulling. Those are not counting any of the collector tractors that are sitting waiting for a restore or the next tractor drive and not counting any recent purchases.
So with us the track record for D series and hundred series isn't too bad........... but I'll agree, nothing lasts forever and every tractor, if used, will eventually fail. Same could be said for a Deere 4020 PS or with the synchronized gear packs, lots of work in replacing synchronizers and expensive! Or a 1066 and its rear end, TA etc. They will fail if used enough, every one of them. Like an engine will only burn so much fuel and that is it.
Wink
I am a Russian Bot
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 8:40am
This happens when you grind it in.
Charlie
Bear Taylor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bear Taylor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 8:48am
I have owned a 170 for about five years and it has been used for major dirt work (shooting range berm), hauling broken tree limbs, drilling post holes, blading our 100 yard driveway and even loaned it to a neighbor so he could finish baling hay.  I did notice it is prone to grind when going back and forth from 1st gear to reverse.  I started slowing down the motor to idle before shifting and so far no jumping out of gear.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 2:19pm
The 170 I just sold to my brother in law has never jumped gears.  Has a loader on it.
The 5015 I have was inclined to jump gears just when you headed downhill towards the pond.  Never got wet, but have some slopes that I mowed with it so did a detent spring up grade, and it has behaved well ever since.
The Mcmaster Carr number is 9595K35 which is a .375" by 1" die spring.  They are hard to compress when installing.  I had to grind off about a millimeter on one of them to get the compression capscrew started.
Edited by Reindeer - 22 Jan 2019 at 2:26pm
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 3:03pm
Do you stop the tractor before you take it out of gear. If not the transmission is still spinning. If you stop first the transmission will be stopped and shouldn’t grind unless your clutch is dragging. I can move round bales all afternoon and not scratch a gear.
Edited by wekracer - 23 Jan 2019 at 6:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 7:40pm
I do like WEK does with my D17 and CA. I think the previous owners of each must have done the same because both tractors shift easily and don't jump. One thing that helps on the CA is I leave the PTO engaged so the hydraulic pump quickly drags the gears to a stop.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 7:47pm
Grandads C still has no issues with the transmission since 1950 that I know of. One thing he did before he started the tractor was to lock the clutch pedal down. There is supposed to be a rod that can be swung into place to do that. He would also do that if he got off the tractor with it running. Latch the parking brakes, put it in neutral, lock the clutch pedal down. Used to also stay on my a$$ if I rode the clutch at all. Said it was bad for the clutch throwout bearing. Guess he knew what he was talking about. Only saw it split for a clutch once in my lifetime, but he had quit farming with it years before.
Dad still uses it for the garden occasionally.
My C on the other hand, jumps out of 2nd and 3rd if you just turn down a slight incline. Probably has something to do with the transmission sitting full of water for lord knows how long before I bought it. Guess I should take a look at that one day....
I know, wrong tractor maybe, but saying the way someone treated it before you get it will have a lot to do with issues you have. Unfortunately, cant go buy a new one nowadays.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 8:03pm
When  I bought this 190 tractor when you let the clutch out in 3rd or 4th gear it would pop into neutral it was so bad,  So I tore it  down and replaced input shaft (4th  gear) along with 3rd and sliding colar. Engagement teeth became arrow head  in shape and this caused gear poping.  DO NOT GRIND GEARS
Edited by Beirnesy - 24 Jan 2019 at 4:42pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
