forklift ujoints
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: forklift ujoints
    Posted: 16 Jan 2019 at 3:25pm
I have an FPD50-24-2PS here and it needs both ujoints replaced in the 'driveshaft'. I'd almost call it a double carden joint  as both ujoints are next to each other.
I'll bet they're originals and never greased.....
Anyway , does anyone have real part numbers or a page out of a book to help?
I really want the replacements on hand BEFORE I TRY to get these out. I know by looking it'll be a struggle from the top. Should I build ramps and try from below ?
Any help is appreciated.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 6:55am
anyone got any info... maybe a close 'relative' of my machine ?
good new is it's too dang cold here for the next week...bad news is ,it's too dang cold..shouldhv put in garage to work on it.
Jay
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:26am
can you send me a picture of your machine, I believe I have a close relative but would have to go outside to building to get model #. but I have the factory service manual which has the part numbers. you would most likely have to get to it from bottom. I have had mine jacked up in air and blocked up to work on it from bottom. I use 2 floor jacks at a time on each side until I can get a couple 5x5 blocks under it. would not be a fun outside project this time of year
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:46am
the beastie....
