Model B Front Weight Bracket
UncleRuckus717 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Topic: Model B Front Weight Bracket
    Posted: 15 Jan 2019 at 11:35am
For a long time, I was looking for a good front weight bracket for my little B. I had some good suggestion and ideas given to me from some of you wonderful fellas. Welp, I finally had enough of steering with the brakes. I went to the local steel yard, and set to work. This is what we came up with. Still need to paint it, but it seems to be working quite well. I can steer the tractor in the snow with a heavy attachment on the three point, now. I am keeping a close eye on the tangs cast into the engine block for cracking. That is my only concern, so far. What do you think?
1949 Model B
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 1:16pm
My concern would would those four bolts that hold the hole front axle.When restoring mine a said it sure is not stronger enough for loader or a lot of weight on front.Memory tells me they are  one half inch bolts .
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 1:50pm
What's the BBC in ,
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 1:54pm
Ok, good to know. At the least I can replace them with new grade 8 bolts. I will keep an eye on those, too.
1949 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 1:58pm
Originally posted by Fred in Pa Fred in Pa wrote:
What's the BBC in ,
Good eye. I am building a pro street '86 S10. End goal is 600hp+, which (if you can believe what you read) shouldn't be very hard to do with a 11:1 496.
1949 Model B
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 3:02pm
Too many weights and too high for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 3:10pm
my concern is block 1/2 the rad area....B guys will KNOW, but it seems 'wrong' to me...
also..
is there support OTHER than them 4 bolts waay in the back ? I'd think 2nd bounce and whamm, weights all on the ground, busted bolts..worse would be the castings...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 3:38pm
I gotta' solution to blocking the grille AND adding some weight. Slide that 496 right under the hood of that Lil' B and ya kill two birds with one stone!  As a matter of fact, that would even add something else' to that cute little B. The "WOW" factor!   See, it takes a hotrodder to think up this cool and come out with a cooool solution......  Thumbs Up
Steve@B&B
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:05pm
Looks like 2 bolts at the rear of engine & torque tube and 1 at radiator support bracket on each side.  How much is this total weight with engine that bears down on the one wishbone pivot bracket and bolt for the front end?
It does look easily weight adjustable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:08pm
Those are 60lbs each. 360lbs total. Keeps the front end down nice when using a box scraper.
1949 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:13pm
also..
You know, I’ve never had to even open the radiator shutters even on the hottest days. I’ve never seen her get above 170 degrees. I tied the weight bracket in to the two tangs cast into either side the of the block, as well. It is supported in four places total. The sides are 3/8” and the front is 1/2”.
1949 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:15pm
I gotta' solution to blocking the grille AND adding some weight. Slide that 496 right under the hood of that Lil' B and ya kill two birds with one stone!  As a matter of fact, that would even add something else' to that cute little B. The "WOW" factor!   See, it takes a hotrodder to think up this cool [IMG]uploads/1/censored.bmp"> and come out with a cooool solution......  Thumbs Up
Steve@B&B
Thanks Steve! Don’t think I haven’t though about dropping that 496 in it... :)
1949 Model B
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:15pm
At first glance, I thought that the only bolts holding the bracket were the 4 back by the
bellhousing. That would definitely not hold.
Upon closer scrutiny, I see you are also utilizing the 2 bolts at the front of the engine as well.
Those two bolts will see the most strain but I don't see any reason why they will not hold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:17pm
OK.... man just HOW do you lift 60# that high ?? 6 times to boot !!!
I'd want (ok, need...)the handles to be a lot closer to the ground...Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:19pm
I’m not sure on the total weight on the front end. I will say I add/remove weights based on the implement I am using, and it never has more than 360lbs (6 weights) total. With 360lbs on the bracket and nothing on the 3pt, I’d have to have forearms the size of an oak to steer it!
1949 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:23pm
Glad to hear it. Those tangs on the front of the block are THICK, so I was hoping it wouldn’t be an issue. I am keeping an eye on them, all the same.
1949 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote UncleRuckus717 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:25pm
I’m only 33? Haha! It wasn’t easy for sure!
1949 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 8:49pm
Piece of cake Jay,,,,,,one on Monday, one on Wednesday, one on Friday, one on Sunday, one of Tuesday  etc.
Getting them all off,,,,,,,,,,,that's what grandsons are for....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 7:52am
If you are happy with them that's fine.As a practical matter the higher the weight is positioned on the tractor the less effective it is holding the front end down as it comes up in the air.Would have been much better all around to add front wheel weights and the
B  slab weights that bolt to the front axle as far as counter balance to the rear.Plus when you hang something with the box blade and the front end goes up 2ft in the air and slams back down having the weight on the front wheels and axle would make it far less likely
to break something on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 1:29pm
Or maybe the Contractor.    ( I know - I'm terrible - I couldn't resist. )
