ac 715 backhoe
LIAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LIAM Quote  Post ReplyReply Direct Link To This Post Topic: ac 715 backhoe
    Posted: 26 Jul 2010 at 1:40pm
can any one give me a lead to where I can get parts for a t-19 transmission ? H ad a bearing fall in and i need a couple parts to rebuild it lost all but fourth gear. local guy said fifteen hundred to rebuild I would much rather buy a used trans for 1/2 as much . Don't plan on driving back and forth to work w/ her.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 2:43pm
Minnpar may have parts and there are a couple of other people on here with 715 parts also.
T19, Borg Warner
Parts
Borg Warner T-19 Heavy Duty four speed with a cast iron case
Ford Trucks 1974-85
Case casting number is 1309
Synchronized in all forward gears
Single step reverse idler gear
Edited by Coke-in-MN - 26 Jul 2010 at 2:44pm
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 9:13pm
Coke, You are one massive source of all kinds of good information!!!
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 4:28pm
Think Coke might have a better lead. these guys sometimes get used stuff in they also have a parts web
http://worthingtonagparts.com/
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
