Well Well I bought a CAT |
Morten.have
Topic: Well Well I bought a CATPosted: 15 Jan 2019 at 2:10am |
Well I indeed need a newer dozer so I bought a cat, before you guys get upset I gonna tell you that I will keep the 16’ for sure!
orangeman
Posted: 15 Jan 2019 at 6:14am |
Morten: Nice looking machines - keep up the good work!
Has the swamp pads too - Orangeman
Edited by orangeman - 15 Jan 2019 at 6:15am |
jerbob
Posted: 15 Jan 2019 at 8:24am |
Nice Tractor Morten. Hope they play nice together. What model cat did you get?
Also meant to ask, how the 16 held up with your ship cargo unload job. Any damage to the beloved HD16? |
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 15 Jan 2019 at 10:23am |
Appears to be a D8C, LGP(Low Ground Pressure) shoes. Going to be loading More ships Morten? By that unit you must have made some good money at it.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8979 |
Posted: 15 Jan 2019 at 8:59pm |
...at least you can easily source parts....
HD6GTOM
Posted: 15 Jan 2019 at 10:30pm |
Looking Good. We understand having to update equipment. Good luck with it.
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 16 Jan 2019 at 1:55am |
As much as i love my D6Ds; and ive got 2 of them. D6C/D swampys are weak in the final drive dept. Drain and Check the final drive oils. And also check the outer deadshaft nut is tight and the sprocket preloads are tight. The HD16s finals are far more solid than the LGP D6s. Also crawl underneath and check where the diagonal braces are for the track frames, grease the bearings on each side; and also one each in outer caps. But mainly check for any oil weeping out of the deadshaft case where the diagonal brace is. You want it to be nice and dry !
Hope all is good in there. Cheers Merv
tits tyres and tracks
they all cost you money |
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 19 Jan 2019 at 1:54am |
Are you going to trick out the cab like you did on the HD? Post a picture of the AC decals I sent you.
Allis Express participant |
