snap Couple to pin hitch
MarkinSIndiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkinSIndiana Quote  Post ReplyReply Direct Link To This Post Topic: snap Couple to pin hitch
    Posted: 14 Jan 2019 at 2:36pm
I am working on a restored WD with pin hitch draw bar.
The customer wants a 2 bottom plow for it.
I have a 2 bottom SC hitch, I also have a 3 bottom pin hitch plow.
Will i be OK to just swap the SC itch for the pin hitch without any other modifications?
Thanks,
Mark C.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 3:05pm
You can switch the hitches on the plow or tractor with no problems.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 5:36pm
I have had one and have seen other three bottom plows with the rear bottom removed making them a two bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 6:06pm
You may want to switch out the 2 eye pieces, on the top, to SC coupler latches, they will disconnect, and keep the plow from hitting you in the back of the head, should the pin hitch fail...Wink
