Embarrasing moment at tractor pull
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: Embarrasing moment at tractor pull
    Posted: 26 Jul 2010 at 6:56am
when you hook to the sled in 4000 lb class and cant move the slid in any gear for spinning.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:16am
What seems to be the problem? Is it the track conditions or tractor issues? I have had those embarrassing moments myself, my problems were ineperience and mechanical, all in good fun.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:26am
Did you try taking off at an angle?
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:38am
burgie it just blew my mind . first time out with this engine .  dad got sick from the heat so i loaded on the trailor and went home.  wished I had tried some heavier classes to see if it was a down on power or over torquing the tires  . when i first let out on the four button clutch and the engine didnt loose rpms . I thought the clutch was gone.
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:19am
Wrong tires (tread cut) for the track or too much air pressure.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:33am
I had a couple od those type moments when I started pulling. Mine was drawbar hight and the front came up to where everyone got excited and DQ'd me. That was why I built my own pulling track to check to my changes and balance.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 11:47am
Happened to me, just sat there and spun, lucky I was the first puller and they shortened the chain 2 links and I was able to move it for a full pull. Chain length matters!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 12:02pm
Did that once myself. Tried to see what the CA could do. Killed it trying to start in 2nd, just dug holes in 1st. Oh well.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 12:37pm
Pulled with  my 7040 at the local fair .. went to hit the high button and the old gal  froze till i hit the low button again ..  embareassed
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 1:35pm
Well Ind. was there I didnt get a chance to talk with him after the embarrashing show . maybe he saw something that could help. I know I missed the weighting altogether but I stll dont know if all the weights on the back would have been enough. tractor is a altogether different animal than it was 2 seasons ago but maybe my memory is failling.
Edited by mlpankey - 26 Jul 2010 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 6:57pm
Well Pankey, you make me feel a little better for this week's pull.  I did ok last week in the 4500 lb. class, but not great.  I am weighted up this week to go in the 6000 lb. class, so it's either gonna be really good or really bad.   I had one pull like that four years ago, my first one.  Spun from the very start and finally did get going but ended up second to dead last in my class, last being someone that broke something.  I almost ended my pulling career after that first pull.  I guess that's the fun thing and upsetting thing about pulling is that just when you got it figured out, it throws you for a loop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:22pm
I don't feel so bad about my experience now after reading this. I tried to pull in a farm stock class once. I was 50 lbs over to pull in the 5,000 so I had to pull in 6000. There was only a JD A in the 5000 and there was a hopped up 560 farmall with an 8 inch drawbar in 6000. The rules said standard 14" drawbar from PTO but they let him pull. I throttled back about half way down the track cause I was spinnin a lot. I don't remember the other 2 tractors in the 6000 but I got 4th out of 4.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 9:05pm
Finishing second when everyone else tied for first is real embarrasing.
WEL(IN&TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(IN&TN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 6:19am
There is no need to be embarrassed. You simply had no wheel hook up at all. Your tires spun on top of the hard clay. With all of the power you had there was no way you were going to move that sled. I saw your dad was sick and didn't want to bother you. Keep up the good work with ACs and we hope to see you at the White Pine, TN pull in November.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 6:22am
I have looked over some notes and talked with some friends. I had only pulled the diesel rear twice before blowing the 310 ci motor up. This new motors increase in cubic inches and 1 point increase in static comp. ratio is definately making more torque. that along with the mechanical torque of the slower gear . Suprised me or was something I hadnt thought about much untill this week. Engine saturday had a verry light tune in it  but will spin the wheels about four feet in high gear across the field with nothing hooked to it when called on with throttle. Its time to weight it up or go back to the higher ring gear or back the cam  up  a degree or four.
