My D19 Build
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: My D19 Build
    Posted: 08 Jan 2019 at 12:23pm
I wasn’t going to post until I finished, but I will probably be overloaded with pictures so I thought I would start now.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 12:37pm
jollymon68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jollymon68 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 12:40pm
Nice I have always wanted to have a D19! Can't wait for the next batch of pics
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 12:48pm
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 12:57pm
1852 Moore Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1852 Moore Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 4:59pm
Outstanding. Got a 19 that i am contemplating installing a front pump on. Let me know how yours turns out when finished, please. Keep posting the progress pics. Thanks.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 6:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 6:37pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 6:59pm
Edited by JC(WI) - 08 Jan 2019 at 7:26pm
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:04pm
Nice job on this 19 and the pump work looks great!
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2019 at 7:08pm
Nice!
Looking forward to seeing the rest of it.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 7:43pm
And an air conditioned cab too! Very nice!
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 8:14pm
where did you find your front pump shaft and coupler that bolts to your front crank pulley?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 11:58pm
For the air conditioning I am using an aftermarket underdash ac unit. On the pump setup I went to the local driveline shop looking for a coupler and shaft to make my own crank pulley hub, and he looked in a book and found a hub and 13” shaft that fit.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 6:16am
nice work !!   You have spent many hours on it to change it from junk to like new. I give you an A+ for the paint outfit you are wearing while painting.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:06am
7060, what was the filter under the tractor when you were painting?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:10am
It’s an exhaust fan to suck fumes and mist down so you can see. It has a fan on the outside wall sucking air through the filter. I’ve got other stuff going on at the shop so I decided to work on it in an old garage at my house, but I’m ready to drive it to the shop to set the cab on now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 10:47am
I did like the one picture with the 7060 waiting in the background watching the progress
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:14pm
Looks good. I really like the styling of the D's.
I like seeing pics like this because I will be painting my CA and I was wondering how far I really need to tear it down to look decent after painting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:41pm
A-C had an optional front "auxiliary" hydraulic pump that sat inside of the sheet metal. I've only seen pictures of it, but it appears the driveshaft was a 2-wire hydraulic hose of some sort. No Love-Joy coupler on the pump shaft and the pump bolted directly to the holes in the front support. AGCOPARTSBOOKS.com page 238 shows the pump and page 268 shows the driveshaft under D-19 tractor info.
Edited by DrAllis - 11 Jan 2019 at 8:45pm
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 9:08pm
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 9:49pm
Looks good  when i did mine the love joy did not stand up to hard hyd use so i used a chain coupler on the pump drive for next 4 tractors that i did     not sure what you are planning on for hyd valves but i found 180 or 185 had good valves that are small and compact and stackable i put 3 spools on all mine
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 8:50pm
I stumbled across the factory pump setup when I was doing research. It wasn’t the GPM I was looking for if I could find a pump to fit there. I wondered what they could be using that they called a flex shaft. I am disapointed to hear about the lovejoy coupler failures. I was going with the chain coupler but the guy at the driveline shop suggested the lovejoy. Maybe I should change that before I get any further. For the valves I cheaped out and got a nortrac 3 spool valve. One for the 3 point and 2 sets of remotes.
Edited by 7060 - 12 Jan 2019 at 8:54pm
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 9:07pm
Edited by 7060 - 12 Jan 2019 at 9:11pm
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 9:33pm
Wow excellent pictures, thanks for posting.  What was the bearing number you used for the idler on the A/C belt?  Thanks
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 9:44pm
For the love joy to hold up it needs a bearing in the adapter bracket with the rubber mounts and such a long shaft without ballincing it the swing will beat the rubber out also move the belt for your alt back the shaft side that takes the extra load off the coupler and side pull on a pump isn't good
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 9:50pm
thank you it looks like a better set up than whats on my i615 I had to weld the shaft to the pulley adapter plate didn't weld strait so I have a wobble and a engine that shakes the other end is a dubble roller chain coupler I would like to redo with a love joy I think I would take out the wobble
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 9:54pm
The alt doesn’t need much belt tension and I’ve seen those pumps belt driven before so I didn’t think the side load would be an issue. I don’t really have the room to move the alternator back or it will get into the radiator, but I could add a bearing. It will only cost my a coupler, pulley, and a little time though so I may go back to the chain coupler. The idler bearings I used two new ball bearings that I had, actually for the trap slides on a Timpte grain trailer.
Edited by 7060 - 12 Jan 2019 at 9:58pm
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 10:15pm
From what I've seen, the belt for your AC is not meant to bend backwards like the idler pully makes it do.
 Works good for skinny timing belts or serpentine belts.
 They do make a belt that doesn't have a flat side.
 Both sides are tapered.
 It's meant to bend both ways.
 Your idler would need to be a tapered pully like all the others.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 10:31pm
The idler was an afterthought I was going to play with. I have another belt 1” shorter that I can eleminate the idler but was afraid of the pulley contact on the compressor. I wanted to try and wrap the belt as much as possible to keep from slipping it.
This page was generated in 0.223 seconds.
