AC6040/160
Plowboy33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowboy33 Quote  Post ReplyReply Direct Link To This Post Topic: AC6040/160
    Posted: 07 Jan 2019 at 2:03pm
I recent bought another AC6040  the 3 point hitch want work. Its about the same tractor as a AC160 except AC had it make in France. anyone have any thoughts on the 3 point hitch problem? It had been sitting for sometime and the guy said it was working when parked.
Edited by Plowboy33 - 07 Jan 2019 at 2:06pm
6040, 2 WD45's one wide one narrow,2 row cultivators,Model 90 pull combine,8 ft drag disc,3 gang disc plow,3 gang flat bottom plow,8 shank Orchard plow,6 foot sickle mower.All purchased new by my Dad
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 4:15pm
Not sure about the 6040 but the hydraulic pump on the 160 will need to be primed if it is parked too long.  My 160 had this issue before I started the restoration.  There is a rubber coupling in the suction line that can age/dry rot and allow air into the system.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
This page was generated in 0.179 seconds.
