clogged spray cans
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Topic: clogged spray cans
    Posted: 05 Jan 2019 at 5:09pm
     This  may be a dumb question but I seem to have trouble with aerosol cans that have been sitting for a long time not operating any more. Most are WD-40, carb cleaner and penetrating oils. Is there any safe way to get the contents out when they won't spray? I  have taken new nozzles off other cans and still can't get them to spray. Does anyone else have this problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 6:14pm
take an awl, and a rag, wrap the awl, poke a teeny hole near the top, to bleed off any remaining pressure, then enlarge, to use as a dribble can...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:19pm
Most are not clogged. They have lost propellant. Kroil is bad about this. I even talked to their lab, they have tried to stop it, just nature of the beast. HTH Tracy
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 8:10pm
not probably recommended but I take the tip off then use a rubber tipped blow gun place it over the little plastic piece coming out of the can then hold them together and blow it repressurizes the can with shop air I have done it many times
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 8:19pm
I use a rubber tipped blow nozzel and put against the spray nozzle, hold firm and apply air and push nozzle down... when ye feel the can start enlarging, quit.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:35pm
I remove the tip nozzle and blow it out wth an air gun. I sometimes swap nozzles with other like working cans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 7:56am
     Thank you for the info. Don't like the idea of throwing away a can that is still  1/2 - 3/4 full of product.
     I have been a little leary of doing much with aerosol cans since one accidently got into the burn pile and exploded. The can landed about 100 ft. away and sounded like a 12 gauge going off and I was pretty close. Glad it didn't aim at me.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 1:52pm
I've done that many times as well. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 1:58pm
When I was a kid, I used to "accidently" see to it that an aerosol can or two ended up in the burn barrel. Light the garbage on fire, get a safe distance back, and wait for the big bang. Could say I was hard up for entertainment living out in the styx where I did. Didn't have video games to play. LOL! Darrel
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 1:58pm
Jerry,,,,,,,,,,,, fer some reason whut you sed there makes plum good sense!!!!!
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 2:33pm
You've lost your pressure so put it back in as suggested, BUT BE CAREFUL! I've had more problems with the tips getting clogged because I forgot to clear them. So pull the tip off and with your fingernails pull out the little red orifice and clean. Sometimes the whole tip has to be cleaned, but if you're careful they'll work as good as new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 2:43pm
Yeah, JC can fall into it every once in a while Joe!!  (I couldn't resist!!  The devil made me do it Jerry!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 5:33pm
that reminds me of when I....... er I mean someone told me a story about somebody, one snowy winter, who was knee deep in diapers and no inexpensive way to get rid of them. This "someone" decided to stack about 6 or 7 car tires one on top of the other, and dump a bunch of frozen diapers in the tires. A quart of used oil topped off with just a glunk of gasoline and poured as a mixure over the diapers. Now approaching this stack with lighter in hand, this "person" decided that maybe it would be best to crouch low when lighting. "Flick", there was a low tone but rather powerful thud and flaming diapers shooting 30..... maybe 40 feet into the air. Funny what a splash of gas can do. One big diaper canon. I wonder what the statute of limitations is for something like that?
Edited by Lonn - 06 Jan 2019 at 5:37pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 5:39pm
Isn't it strange, how an aerosol spray can neatly fits into a female drive shaft guard...
Also, its funny, that if you drop said can, into said guard, with the valve end down, and the guard's lower end is in a burn barrel, the valve will melt out, and launch the flaming can several hundred feet up and out, like a mortar!
Not that I've ever done it, but...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 6:32pm
Reminds me of utube video overseas, these guys were huffing propane under upside down empty 55gal drums with a tube and then sticking a rag torch near the edge. They would launch a 100ft or more in the air with a boom!
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 7:11pm
Since we are a little away from cans...this is a true story.
Guy had an old cistern that he filled with brush, grass clippings, etc.
It was full and so he dumped a couple gallons of gas in it. I bet you know
what comes next...match did not light a couple times so the fumes are really
built up. Next thing he knew was he was being picked up off the ground. The thing was like a cannon with limbs, etc still coming down. Ground was cracked.
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 8:54pm
the spray cans say to turn up side down spray some to clean out before you put it away.  next time should work better. if there left in the cold there junk;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 9:12pm
Then there's THIS story...Wink
[TUBE]zzabmVIU6EQ[/TUBE]
ihscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ihscout Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:51pm
I use a 3 gallon Plastic bucket that pool chlorine comes in. The lid twists on and it's a couple inches taller than say spray paint cans. There's a hole in the lid that a screwdriver sharpened like an awl fits in. I tape the can I want drained inside the covered bucket then tap the awl with a hammer. Even if the contents is under pressure all stays in the sealed bucket.
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 10:06pm
PBlaster is bad for losing pressure. I just smash the can and it will compress enough to get some of it out
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 11:07pm
LOLOLOLLOLOLOL On the TNT video. I have seen it before. Funniest dangest thing I have ever seen!!!!!!!!!!!!!!!!!!!!!!!!
