D19 power steering lines?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: D19 power steering lines?
    Posted: 03 Jan 2019 at 7:53pm
Working on making some room for an a/c compressor, and need to reroute the bypass line going to the power steering pump. I’ve read some people going to hoses, but what kind of fittings did you use? I would like a short sweep 90 coming out of the front end. It’s an inverted flare at the pump end like a brake line, but not sure the thread or how to get that to hose. The other end sticks down into the oil which I assume isn’t necessary?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 7:56pm
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 8:18pm
I would have to look it up again, but I am fairly certain that is the oil suction line, which would make it necessary to stick down in the oil.
Nope, I was mistaken, that is the pump bypass, my guess is it needs to be under the fluid level to keep foaming to a minimum.
Edited by Orange Blood - 03 Jan 2019 at 8:25pm
Still in use:
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 1:30am
Air Conditioning on a D19... I’m intrigued...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 6:19am
Just whack off that steel end off the old hose. Flare the steel tube end a tad and slide on a hose and hose clamp it. Do the same on the other end. There's nothing ever going thru that hose until you crank the steering wheel extreme right or left and hold it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 6:56am
Make sure that chinsey nut on the PS pump pulley is tight. I never used those OEM nuts. I always used a regular 1/2" NF nut and Loctite so it would NEVER come loose and ruin the shaft and pulley, which is what usually happened to them.
