HD5B Starter removal
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: HD5B Starter removal
    Posted: 03 Jan 2019 at 1:28pm
I finally got it out but what a pain. First I had to drop the pan that attaches to the side frames. This was a big deal as the pan was so full of dirt the dirt covered about half the starter. Add moisture and a temperature of 20 degrees and you get a block of frozen dirt. After I got the pan bolts out the pan didn’t drop. I had to pry it from the frozen dirt. Then I had to chisel away the frozen dirt to get to the starter and starter bolts, not fun. The dirt was a perfect mold of the pan. Frozen around all the cables and hoses. The next issue was getting the bolts out. The bolt heads were all 12 point and all a different size. Normally that wouldn’t bother me but when you’re 6’-4” and have to enter weave my body with the frame of the blade it gets challenging getting in and out. Anyway I got it out and putting back in should be a whole lot easier.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 1:54pm
Dennis,
Good work and perseverance will pay off. What's the starter issue? Not working I assume?
 Are you getting it repaired? I did my (off color) starter so many time I had wing nuts on all the spots!:)
I need to go out and fire mine up! Just to see it the $600 starter repairs, cables and battery are still good!
I dont have to take my pan off for the starter, but did drop the pan and clean it and it was in the summer so it wasn't frozen but packed with dirt too! Not a fun job! We need pictures too!
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 3:50pm
Welcome to the world of bulldozer repairs... a lot of the repairs are far from enjoyable. I'm sure your starter is an MT40 and if you put in a good one you'll likely never have to work on it again. I had one of these starters on a Detroit 8V92, I don't know how long it had been in there before I bought the truck but I had the truck for 17 years... my "bread 'n butter truck" and often started it many times a day. I never had to pull the starter in all that time and then I sold the truck... there's a quality Delco starter for you. It is important to have good cables, connections and batteries so that it's not having to be starved for current. Please let us know when your machine is all back together again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 5:22pm
Be grateful were space saver head bolts, the originals would have been 15/16" hex and a royal bear to get a wrench on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:34am
Wow, that would have been a pain.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 1:39pm
M42 replacement - a wobble head socket and long extension - been there many times before i replaced the starter with new type with solonoid . I seem to remember bolt heads being 3/4" (1/2" bolts) and those new style bolts that look star shaped only being used on much later applications in heavy truck use.
 Seems if this is first time you have had belly pan off then changing oil has not been a regular occurance as when the small trap door on belly pan is removed the dirt level is easily noticed .
 Then I pressure washed my machine a couple times a month or more often and removed the excess dirt that accumulated .
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 2:38pm
Taking off my belly pan this spring. its packed under there for sure. The access plate for the oil changes was clear so no problem changing oil on my 16. Just ran out of time this year to dump the pan. Anyone have any pics to show of when you did your particular tractor please share. I now we would all like to see them.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 2:49pm
best way.  pull onto something solid.  use a floor jack and pump up tight, remove bolts and get out of the way lol
belly pan that is
Edited by CAL(KS) - 04 Jan 2019 at 3:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 4:47pm
belly pan that is
Exactly what my plan is Cal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 6:05pm
Off color sorry.
Edited by Sugarmaker - 04 Jan 2019 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 6:42pm
Need to rehab the one on my 7G, been nose mangled a few too many times and difficult to get back up as does not align well anymore.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 8:38pm
After having trash and oil catch on fire my uncle became a big believer of washing his dozers down. This was back in the 50's with his HD 14c. But the same process for the HD21 and the FD 30.He would use a 200 gallon water trough with gas engine pump,1 1/2 hose and a 1/4 inch nozzle on it. Volume as well as good pressure.
In his early years mostly clearing brush to make farm land. So some fishing of big sticks,but the leaves and dirt move with volume. Generally did not remove belly pan to clean them up,just the little plate you remove for oil changes.
Edited by Ray54 - 04 Jan 2019 at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 2:01pm
Thank you for shsrythe great belly pan pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 4:36pm
thats the thing if you clean on regular basis - the debris will wash out at end near cross brace . Have done it on regular basis many years as it seems working on some part of machine is always needed ans sure nice not to have to fight grease and dirt .
 Have used a sheet of plywood and floor jack a few times also in the center of sand pile to take pan off also -
Edited by Coke-in-MN - 06 Jan 2019 at 4:37pm
