190 X/T
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Topic: 190 X/T
    Posted: 02 Jan 2019 at 6:59am
  Howdy,
  Never had one so whats the good and not so good on this tractor?  Cab and bare back.
Thanks Kurzy
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 7:44am
What year is it?
Gas or Diesel?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 7:49am
  Howdy Charlie175,
  Fellow selling for a neighbor so no idea on year. X/T came in gas also? Its a diesel.
Thanks Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 8:09am
  Howdy,
  Its a bar grill so must be a 66 or 67.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 9:56am
They came in non-turbo versions also, so beware even if it says XT
Rough timeline (Correct me if I am wrong)
64-65 were the same.
66 had factory updates for shifting (Something else?)
68 had larger axles, fender, other minor updates (Series II)
69 series III had Rear end updates to beef it up.
Depends on how they were used, if pulled/used hard (Overweight) the rear ends had issues on the early years.
Cavitation can be a issue on all years.
Gears can be a problem if abused
Slow travel speed.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 9:57am
Yes the XT came in gas version also with the larger 301 gas motor.
Charlie
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 1:04pm
Any 190 or 190XT built from 1966 and on had larger axles and most of the earlier XT's had either larger axles installed or harder axles installed through an Allis Chalmers update program.
Wink
I am a Russian Bot
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 1:51pm
I have a gas 1966 cab 190 it has great power steering the seat and controls are comfortable and well layer out. They run very smooth and mine is quiet. The cab Is old technology,No AC and my heater has been removed. I do pull the pin and remove the lower door in the summer and leave in the shed. With the windows open and the door removed it pretty comfortable in the summer.The power director shifts easily berween two speeds. You must clutch to get any other gears. A power shift is nicer. I have the manual PTO so must use the clutch fo PTO work and I only have the 540 PTO. Hyd PTO and 540/1000 PTOs were an option. The hydraulics seam to work the same as other tractors mine has Pioneer couplers so I connect to other farm equipment without any problems. The three point works as well as any other. I have borrowed implements from the farm.
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 1:58pm
Be carful they had trouble with the rest end . I had the series 3 and broke the ring gear and pinion plowing . It was my main tractor so it did a lot of work too.O rings leaked in the bottom of sleeves so overhaul job too. Good tractor lots of power and nice to run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 9:42pm
Like any other tractor no matter the brand it depends on how they were used and treated. Especially the series II and III, if they were used as intended by the factory few problems occurred with the rear ends. As Charlie stated, problems occurred when tires were loaded, heavy weights also hung, and pulling equipment far bigger than they we’re intended to pull. In most cases they would pull it just fine but anytime you continue to do so, problems from the extra stress took its toll. Charlie and I both have series II 190XT’s, neither jump out of gear, and are strong tractors. Thankfully, previous owners apparently didn’t abuse the transmission by shifting the main gears on the go which was a weakness in the XT. Series III was the best XT, it received the heavier 4 pinion rear end which solved a lot of the earlier problems. Drive it, put it in each gear, make sure the power director shifts smooth but firm. If possible, put a load behind it and go down a steep hill if you have one to see if it pops out of gear when you pull the throttle back. 3rd gear was the most usual gear to pop out but try all four. Great news if it doesn’t jump out of gear, expensive to fix if it does. They are a great tractor IMO, as long as they haven’t been abused.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 5:42am
In my opinion the 190XT was built for high speed farming, like Case advertised once in some of their literature in the 70's, and the Allis Crop Hustler series stressed. Meaning pulling a smaller implement faster and in the end you're more efficient and easier on your tractor and probably do more acres in a day. So find a plow or disk traditionally pulled by a 75 hp tractor in your soil and hook the 190XT to it and pull it faster or throttled back. I wouldn't pull a disk much faster than 4 or 4-1/4 mph so throttle back.
Edited by Lonn - 03 Jan 2019 at 5:44am
Wink
I am a Russian Bot
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 8:13am
I also think the 190/190XT got a bad reputation because of owner/operator abuse.Most tractors I see in their manuals were sold to have fluid in the tires and a set of wheel weights or maybe two.Some manuals state if the tractor was loaded over a certain weight the warranty was void.Go and put a set of duals and a lot of extra weight,turn the injection pump up etc and then have drive line problems.Who is to blame? Not the tractor its being abused.Turning a tractor designed to have a working weight say of 10,000 lbs and 100 HP and turning it into a 15,000 lb tractor and 130 HP with dual wheels is about guaranteed to have  issues with the rear/trans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 10:21am
  Howdy,
  Fellows a big thank you. I be looking for a few of these problems when I go to see this tractor. Its got the big tires on rear that book says is for rough terrain, rear sectional weights and front slabs. Straight metal and pre air cleaner with pipe that goes to exhaust stack.  Sure looks tough with them big ,wide tires on!
  Thanks Kurzy
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 9:17pm
Originally posted by Kurzy Kurzy wrote:
  Howdy,
  Thanks Kurzy
Was this the one that was  on Craigslist north of Bozeman last year?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 9:36pm
Surely not saying dual wheels with the insides loaded is a sin, as there are certain soils that demand the extra traction. Factory pictures show XT’s pulling 20’ disks with this set up. Another picture with just singles at the rear. Mine has the full factory front weights, and loaded rears, no duals. As for the 20’ AC disc, I will find out in the spring how she handles it. Charlie and I are refurbishing one now that we bought earlier last year.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 10:00pm
maybe you can tell the year by the serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 7:44am
   Howdy.
   Eldon, no not north of Bozeman. Maybe this tractor is moving around? Harold, soon as I get to see this tractor I'll have the year down pack. Fellow selling for a neighbor and cant get back there to get serial number.
   Thanks Kurzy
