180 D doesn't start when hot
Stuart OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuart OH Quote  Post ReplyReply Direct Link To This Post Topic: 180 D doesn't start when hot
    Posted: 25 Jul 2010 at 3:49pm
 Hi, I have a diesel 180 (1967) that starts and seems to run fine and will run all day(at least 5 hrs.the most i've had it running)or untill I pull the shut down knob. When I try to restart a couple of minutes later it just turns over does't fire, but will restart about 15 to 20 minutes later (the block is still quite warm)but seems to struggle (rolls over a couple of more times then when cold). I've seen at least one posting where someone had this problem with a combine but the solve was the fuel shut off solinoid (went thermal) which doesn't apply. I have checked the fuel flow to the pump, and it seems fine, and I have primed the system without braking the fuel system thinking that it may be pulling air into the fuel lines.  Is there a possibility that the manual fuel shut off is getting stuck, or the pump is suffering from some sort of internal vapor lock, or external from the pump to the injectors . I havn't cracked a fuel line yet to bleed air but would think that I would see fuel on the side of engine if this were the case. The engine has about 7000 hrs on it uses oil (mainly leaks from valve cover) but doesn't smoke excessivily.Thanks for any help in advance and sorry about any spelling errors.Stuart
rob(ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob(ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 5:55pm
Yup, worn injection pump barrel. Try pouring some cold water over the pump next time. Will contract the barrel and fire off. Might get lucky and be able to increase the charge pressure and get along for a while, but a rebuild is coming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuart OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 9:27pm
 Thanks you may be right about the injection pump barrel, I'm not so sure about dumping cold water on a alumimum housing but maybe warm I think I get the drift of the check you suggest. The only problem I've ever run into like this one was running a Cat. truck engine out of fuel at the station while refilling, an it stopped running. I had to crack an injector line to bleed the air off of the high pressure side, start the engine and then tightened the line back up. I didn't consider the housing expanding and dropping the pressure enough to prevent the injectors from firing on a running engine. I had it figgured that the system was getting air in it or a check valve was getting stuck  stopping fuel flow in the pump.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 6:31am
There is a valve in the injection pump that maintains pressure in the injector lines.  My guess is yours is sticking open when hot or leaking.  I had a pump rebuilt and it came back doing just what you describe.  Cost a lot of money at the pump shop that put in the defective valve as others as they could not get the pump as hot as on the tractor.  Old service manager fixed it for me.  I think the valve was like $24 or there abouts and a hour of his labor.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:12am
180/185's had such a low roller dimension, that a little wear in the head and rotor shows up, especially hot. usually a rebuild and adjustments can cure the problem.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 12:46pm
Neighbour had the same problem last week on a L3 combine with 670T engine.
Had to rebuild the injection pump. Worn rod or something. Only a starting problem when hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuart OH Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 11:40pm
Thanks Guys for giving me a place to start looking. Even though I've been around diesels for about 20 years I had never heard of this sort of problem. I bought this tractor 2 years ago and may have been this way when I got it, or maybe just started. It's usually start it, do what ever,shut it off untill next use.
