Value of a CA
rsncain1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rsncain1 Quote  Post ReplyReply Direct Link To This Post Topic: Value of a CA
    Posted: 31 Dec 2018 at 2:28pm
What do you think the value of this CA would be.  Thinking about buying it.  The owner says it runs has all the tin and new front rims with tires.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 4:05pm
When I see a tractor that the seat has been cobbled up like that, I get worried about that else was cobbled up! It's pretty hard to tell unless you can hear it run and drive it.
My opinion is about $500.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 4:48pm
Dose he have a price on it ? .Rear weights ,new front rims  n tires are worth $500.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 5:07pm
It's definitely worth $500 for parts.
I guess my point is that if the original poster is looking for a tractor to run, I, personally, would look for one that I could hear run and drive. It's easy to get into very expensive repairs on a tractor like that.
A couple years ago, I bought a D-17 that wouldn't turn over. The guy told me that he had run it a couple months before (which I now know was BS). I bought it quite cheap. I soaked the engine with acetone/ATF for a couple months and kept trying to turn it. Finally, I pulled the base off and unhooked the rods. The sleeve on the stuck cylinder was all pitted and it was all my 20 ton press wanted to get the piston out.
If you buy it and it needs an engine job, a complete rebuild can easily be more than the tractor is worth. CA's are pretty common and not that expensive. If it was a model that is quite rare (A, U, IB, WF, etc.) it would be a different story.
I can say, with a lot of personal experience, it's very easy to put a lot of money in a tractor that will only be worth $1000 to $1500 when it's all done.
My advise would be to have the guy get it running and drive it, if he wants to sell it. If he won't or can't, I would keep moving until I found a good runner.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 5:10pm
To the buyer it may have different prices, If you are going to restore it,it  is one price , however if you need the good parts (parting out) it could be another price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 7:35pm
I have spent way too much money on tractors that I have brought home. A couple were family tractors. So I guess I justified that expense. On most of this stuff they could almost give it to you and you would still spend a bunch of money and or time getting them back to good working order. Taking them to a refurb, clean and paint tractor (RCP) as mentioned you will have more into them than they are worth. But there are much worse things to do than play with these old tractors. And the satisfaction when your done! Priceless!:)
Rear tires and rims can set you back $2000. I would say the value is Ok and you should bring it home if the engine is loose.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 7:55pm
Good fenders with TB sticker still on it means it was shedded most of it life or repaint,good looking battery box,good tires and rims,wheel weights,good grille.I'd go $700 from the picture and bet it'll run with a little effort if not I'd make $$$ parting it out.Might want to inquire about the seat sort of looks like an A or U style seat,might be another deal around.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 8:08pm
i got a add on hear' nice running ca; priced right' can get on an go' with good rubber. never heard from anyone.$1500 obo' one sold with stuck motor sat for years someone gave 1100 for it at a sale' an all the tires junk' an one back rim junk' why is that ? can't see it..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 8:25pm
You should know by now most hard core AC folks are 1st class cheapskates,gotta get
outside The Circle to get the BIG  $$$$(LOL)
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 9:37pm
I'd do $500 on a non runner
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:29pm
gary; don't thank thats big money for a good ca tractor with everything on it runs good dose what it should ?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 4:43am
rs, I see you are in IL, check out dawn's post.
My thoughts on that one is if you are running a scrap yard that one may be a candidate for whole sale scrap price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 4:52am
The original poster never posted a price. I was the one that threw out the $500. I suspect the asking price is more than that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 6:13am
Well yes and no,if a buyer was was set on a CA then its probably a good deal.But in the
overall tractor market for someone just looking for a tractor to use $1500 will put a buyer
in the area that can get something like a D14 or D17 bought.Plus less people all the time out there that want a tractor they view as 'off brand' especially with a different hitch like a
snap coupler or a Farmall Fast Hitch. I saw (and bought a few) really cheap tractors at auctions last year and some crazy high prices too.But if a person holds their cash and
waits sooner or later a real bargain will come up these days.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 6:24am
WF Owner and Sugarmaker gave real good advice IMO
Post Options Post Options   Thanks (0) Thanks(0)   Quote rsncain1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 6:31pm
Thanks for the replies. A guy had it and said he would sell it for $1000. I thought the value might be there.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 7:17pm
If it runs and drives and the hand clutch works, maybe $800.  But it looks like it's been sitting there for a long time.  Might be better off passing that one up.  If I ever bought a CA it would have to be Snap Coupler too.
farmboy59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 10:36am
I just parted out a wide front CA that was complete with snap coupler. It was stuck though. We paid 500 for it nothing was really messed up or worn out other than the engine or seat. Personally, if that guy wants 1000, I'd at least want to hear it run and drive it. the sheet metal is easy to put on if he has all of it and its good and it runs and drives I'd totally pay 1000. the way it is, I'd also go with 500. Just too many unknowns without driving it.
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 4:24pm
If the tires and rims are good and it runs and drives OK then yes the $1000 is pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 6:11pm
I noticed that the hand clutch doesn't look like it is there.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 6:31pm
Looking at the picture, the back tires look like they might be OK with a bit more air.  The front on this side appears to be cracked next the ground.  Would pay to look the tires over carefully for cracks and bulges, and rusty rims.  As Sugarmaker pointed out, easy to drop a couple thou into rims and tires.
If we chased around old tractors to make money, we picked a hard way to earn it.   Mostly just enjoy the time and memories that come with doing this.  And the challenge!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 8:50pm
The CA is a neat little tractor, ours has a woods L306 belly mower on it and it does a great job for a 1952 tractor. Believe dad paid $1,500 at auction for it 15 years ago. Had a 2 bottom plow, sickle mower, front and rear cultivators to go with it. It was well taken care of and runs very well. With that being said, I see several CA’s for sale locally between $900-$1,500. Good looking tractors and they say they run well. The one for $1,500 has a recent paint job, decals,new clutches, and brakes. So to me, $400-$500 would be more in line. JMO
