Allis A
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: Allis A
    Posted: 31 Dec 2018 at 10:48am
Hi, does anyone know where to find on a A the engine serial?
And also if I can find the number for what compression ratio it will stand?
Thanks!
AC: B / WD / CA / WC unstyled / U / 7060 / 710
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 10:58am
Serial # is on the left side of the block. A G is for gas and a K is for distillate fuel.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:14am
Unless you have the piston out ,its hard to tell what compression is .But if you can bore scope it , Kero piston is a dish ,Gas is flat top .Pin to top of piston height is how you tell what compression is .
nonetheless ,still dead.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:37am
To find your compression ratio grab the crank handle and pull it over center 4 times.
If your bag drops halfway to the floor it is kerosene compression however
If your bag hits the floor it is gasoline compression
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:11pm
Butch: i always wondered what that was telling me!
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 4:32am
Thanks for your answer, but do you know where exactly on the left side? Ours is repainted, I can’t find it 🤔
I found the compression ratiao’s belonging to engine serials in Norm’s book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2019 at 6:43am
The engine number is located between the hand hole covers on the left side of the block. The stamping was usually pretty shallow so multiple paint layers or heavy weathering may hide it.
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 1:28am
Ok, thanks!
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 6:53am
Ain't the original bore stamped on the oil pan or block somewhere? I think it is on mine, I need to look, but sleeves may have been changed on yours.
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 1:27pm
I found the number, thanks!
Does a Model A tractor only have a water drain plug under the radiator?
Our other orange friends have 2 drain plugs (one on radiator and one at engine?)
Just to be shure before its freezing....
Thanks!
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 9:58pm
The A has only 1 drain plug under the rad.
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 2:52am
Allright, then it should be empty now. Another question: Does this engine have wet cilinder sleeves or dry? Thanks again!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 3:39am
Wet...
