eliminate points on B110
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Topic: eliminate points on B110
    Posted: 30 Dec 2018 at 12:36pm
What parts and process to eliminate using points on my B110 without changing anything else if possible? TIA
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 9:13am
you have to have the flywheel re polarized on the cast iron engine blocks,   the aluminum block you just get a new armature  (coil) it has the plug in it that plugs the plunger hole
