Low oil pressure sender on HD6G
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Topic: Low oil pressure sender on HD6G
    Posted: 29 Dec 2018 at 10:36pm
While im waiting for my manuals, or a posted wiring diagram i was wondering if anyone knew where the output of the low oil pressure swich goes.
This switch is mounted on a T that screws in right at the oil pressure gauge. The switch is round with two screw terminals on the top. One of the terminals is connected to power(negative side of batttery) and the other terminal is connected to a wire that descends toward the engine compartment where it terminates with a buch of rat bite marks. No sign of the other side of the wire. I assume the rat took it
Does the switch cause a valve to cut fuel to the motor? If so i assume its bypassed durring cranking? Or is there a flapper valve to cut off air? Or perhaps just a horn of some type?
Leo
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 11:11pm
Leo..Can you post some pictures? Do you know the serial #? or year model? Not sure but the oil pressure switch is probably the one that activates the charging system...nothing to do with the fuel system. Fuel system should be a manual shut off.
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 1:03am
Sure, in the morning ill take some pictures.
Where can i find the serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 9:55am
Serial # could be on a plate on the dash below all the gauges....if it hasen't been removed.   Is also stamped into the right rear side of the case below the bottom of the fuel tank...that one has not been removed...but may or may not be visible depending if there is an attachment..winch or rippers etc.  If there is nothing on the back it should be easy to find
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 12:49pm
Hi Mel,
Can you tell me more about this charging system? I have never heard of a charging system that's gated by oil pressure.
Did it simply delay charging until the motor was up and running? Did it disconnect the batteries through a relay to prevent them discharging by back feeding through the generator? Was it a direct tap to tell the regulator actual voltage at the batteries so as to prevent the voltage regulator from being fooled by voltage drop across the high current wiring? Was it for sourcing power for an excitaion voltage to the generator?
No one has posted a wiring diagram yet, so need to wing wiring "her" today on my own and it would be nice to know what that darn wire does, or more accurately stated, used to do?
Note to gals and the PC crowd. I have decide the tractor is a her because it did not come with a manual or directions, same as my wife
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 1:39pm
The switch on the tee at the back of the oil gauge is to operate the hourmeter. You can view the parts book on line at www.Minnpar.com. Click on parts books, select crawler loaders, then Allis and Fiat, You should find the 6G parts book there. Looks like you may want to have your serial number in hand.
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 1:48pm
Jim, you are a God. My wife thinks so too, as does the propane man.
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 2:19pm
Jim,
You are still a god, but the link seems to show a teaser manual. Pages 1-6 and then jumps to page 66 and the cuts off a few pages later.
Am i looking at the right manual. It says "service manual" on the cover, and you said "parts manual" in you post so im thinking i might have gotten it wrong.
Leop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leop Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 2:26pm
Never mind Jim. I found the right parts book now.
Thanks again.
Sincerely,
Leo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 2:44pm
I believe you will have to purchase a service manual unless someone has one they chose to give you. There are not many free, downloadable service or operator manuals for most equipment.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 9:11pm
If you can get to a parts book on line check and see if it was not a generator rather than alternator when new. If it started with a alternator it could be part of that,because older alternators needed to be excited to get them charging. Running power to a oil pressure switch "automated the system", to get it started and not having a switch to close to keep from draining batteries when not running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 9:23pm
Parts book shows the switch is for the hourmeter. Original equipment appears to be 24 volt generators in the parts book, when checked against the Delco numbers.
