CA with high range gear box
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Topic: CA with high range gear box
    Posted: 28 Dec 2018 at 5:37pm
I came across a CA with the high range gear box that is for sale. The gear box is between the trans and the torque tube. The tractor has newer tires and has nice paint. So my question is how much value dose that high range add to the tractor? Thanks
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 6:11pm
Do you know for sure it is an "over-drive" ??  I think they were made both as an under-drive and an over-drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 6:35pm
The guy that has the tractor told me it is a high range gear box. Thats all I know about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 6:39pm
The box looks like this one in the old post from the forum.
https://www.allischalmers.com/forum/can-b-transmission-ratios-be-changed_topic127929.html
Edited by ZachD89 - 28 Dec 2018 at 6:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 7:04pm
With a series 2 D-15 governor spring that would make a nice tractor ride unit.
