Traction Booster Spool stuck
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Topic: Traction Booster Spool stuck
    Posted: 25 Jul 2010 at 1:01pm
I just had my 170 painted, and although to the painter's credit, they were very thorough, they did get some paint on the traction booster spool.  While out mowing I must have tripped teh traction booster, because the spool went into the housing and won't come out.
I,ve tried getting pliers on it, although it is in a difficult spot, but it seems pretty solid.  Any suggestions?
For reference, another post showing the same parts is:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 10:17pm
If you don't have a parts book to see a diagram go to the AGCO parts books online to show you.  Use Internet Explorer as it won't work with other browsers like Firefox:
http://www.agcopartsbooks.com/EpsilonWeb/login.aspx?region=NorthAmerica
The parts diagram will help you see all the parts in the TB valve assembly.  If it's stuck in you can push it back out by removing the rear cap and tapping it forward.  The rear cap is held on by two allen wrench screws and spring that pushes it forward is inside the cap.  Once you have it pushed forward, I'd try to get any overspray off with a scotchbrite pad or some very fine emery cloth.  If you try to remove the whole spool from the body out the rear without getting the paint off, you may damage the very fine tolerences of the spool body dragging it out the back and getting paint contamination inside.  Post back again if you have more questions.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:40am
Thanks Mike,  I  have the parts book, and was wondering about tapping it out from the back, but will get at it tonight, time permitting.
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:54am
You might have good luck getting the paint off with carb cleaner if you spray it in a little cup and dab it on.  That way you won't eat the paint off of everything around the spool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 11:13am
I do have some carb cleaner, but would that be a problem for the wiper seal on the spool?  I had thought a bit of varsol on a scothbrite pad might work too.  Any thoughts on the best option?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 11:16am
You might be right about the wiper.  I'm not familiar with that valve.  That is why I mentioned dabbing it on so you just get it on the paint.  Fine scotchbrite or very fine emery cloth might be a better idea.  Just didn't want you to scratch the spool up.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 11:17am
Can you tape around it and paint on some gel paint remover.  I would be worried about buffing the spool too much.  Be careful not to get it on the seal.  I assume you can push the spool out far enough that the paint will be out past the seal enough to make it work.
Edited by Rawleigh - 26 Jul 2010 at 11:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 10:11am
Yesterday afternoon, I removed the rear cap on the traction booster spool, and tapped it forward, to its maximum travel as you suggested.  Then with some varsol on a bit of scoth brite, I started carefully removing the paint.  I could only get to one side of the valve, but I found I could rotate the spool by putting a socket on the rear of the spool where the spring retainer is held on by a bolt into the rear of the spool.  This allowed me to work my way around the spool, taking off the paint.  I also applied lots of WD 40 while working to clean the spool. Eventually I got most of the paint off, and the spool moved freely once again.  All good, and thanks very much to all of you. This discussion group is an excellent source!!
