Buda Diesel Heads ???
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Buda Diesel Heads ???
    Posted: 26 Dec 2018 at 9:15pm
Can a series I or II D17 Buda Diesel Head with water pump mount on the head
be used on a Series III or IV engine with water pump mount on the block?
That is with a "blanking plate" covering the water pump mount hole on the head of the older style (series I or II) head.
Thanks in advance.
Edited by Macon Rounds - 27 Dec 2018 at 8:22pm
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 9:22pm
are you wanting to keep the original water pump location?
some other considerations if not.
 your fan blade is now that much higher, might need a different radiator or shroud.
longer fan belt, but not sure if the pulleys will line up either.
i believe that there was two different style injectors used.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 10:05am
Yes they can. That is how mine is, a block off plate on the block, pump on the head.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 11:22am
what head is the hardest to find?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 12:37pm
Think  I have a diesel head off a D19D I'd sell and might have a Cockshutt 40 diesel head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 2:42pm
OK Great !!!!
I have an 17 IV and would like to keep water pump on the block.  Just needed some forum feedback to confirm my thoughts about the heads.
Now the injectors Hmmmmm.... I had not considered that.
Can the Later style injectors be installed in the earlier style head ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 6:23pm
i had to drill the injector bores out for my D19 head to fit the injector.
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 8:18pm
interesting....
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 8:28pm
As much demand there is for these heads it's a wonder someone hasn't had some made by now. I know they not cheap but what we gonna do in 10-20 years from now with all the decent ones are used up?
Can't fix stupid
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2018 at 10:45pm
I got a good 17 1or 2 head here for sale been to shop and check good PM for more info on it if any one need it .
