180 Allis frame and seat
Roundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Topic: 180 Allis frame and seat
    Posted: 24 Dec 2018 at 5:18pm
Looking for metal frame for seat and seat for a 180 Allis from transmission case up.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2018 at 8:37pm
is a 190 the same.
1
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 5:47am
I have what you want here in Maryland. You can have it if you come get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 6:41am
The 190 track and seat suspension is the same as a 180, but still need the mounting bracket for a 180.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 7:51am
Is this the same 180 that had 3 point issues hitting the seat ??
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 2:59pm
By the OP's title I'd say yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 4:46pm
Yes it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 5:11pm
Where can I find rods and bushing and rubber grommets to rebuild what I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 5:21pm
So, why was the seat getting smashed by the 3 point hitch ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 5:28pm
Apparently my first question was too subtle?? And like Doc asked, I might not replace the broken seat parts unless 3 point wasn't going to be used again or fixed. But, I am curios as to what the problem is/was because we run one and I want to keep an eye out for a potential issue.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 7:24pm
Roundman, parts are available thru several venders on this site. DJS and Sandy Lake are 2 of them. Also still can order thru AGCO dlrs.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 8:44am
The 4 white rollers that the seat assembly adjusts back and forth on are no longer available from ago.  If yours as still good, you will have to reuse them.
I had my local fab shop make new pins and bushings for my seat.  But the vendors here are a good source as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 4:55pm
for some reason three point hits seat bracket and bends the main bracket that bolts to the transmission.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 5:19pm
I have an idea what might be going on, but gonna need a picture to confirm my suspicions. Have you owned this tractor long?
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 7:15am
The cast iron top link bracket on the tractor could be on upside down, but I still think it's an implement issue with where the top link connects is too high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 7:38am
I own a 180, 3 point never gets NEAR the seat, WTH could be wrong???
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 8:15am
Catorgy 1 equipment on cat 2 tracctor with cat 1 top link in lowest hole on tractor wish origanl poster would pit picture on here otherwise we all just guessing
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 12:09pm
Yes a picture! I don't know much but I do know it didn't leave the assembly plant bending up the seat bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 12:36pm
Yes around twenty years.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 1:45pm
For me it was the implement problem that made it hit the seat.  I can't recall if it was the rear blade or the bale fork.  So I just put the quick hitch on it and solved the problem..Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 10:54pm
Sorry it isn't the three point that is hitting seat frame it is the top link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 10:56pm
Bale fork
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 9:15am
Understood...It was the adding of the quick hitch that eliminated the link from hitting the seat...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 3:07pm
Thanks to all for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 6:43pm
Thanks used Sandylake very helpful Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 6:52pm
I have a
180 Allis. what should the top link length be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:14pm
The Cat II top links we've used for 40+ years measure about 21" to 27" extended, this is measuring center to center on pins. We've almost always used the top hole on tractor and top or middle on implements.
Measured length on blade is 24" and the bale carrier is 23.5" . Top link is a long ways from the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:25pm
If a quick with fixed it and that's all you changed then ist deff equipment related
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roundman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 3:35pm
Thanks
