MF Manure Spreader Apron Chain |
JimWenigOH
Topic: MF Manure Spreader Apron ChainPosted: 19 Dec 2018 at 7:36pm |
I have a MF 3719 Manure Spreader that needs some slats replaced. It has the T-rod type chain. Anyone have any experience on how to disconnect the chain links in order to get things apart?
shameless dude
Posted: 19 Dec 2018 at 8:16pm |
prolly hafta do it from undernieth
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Posted: 20 Dec 2018 at 10:11am |
Jim, Pioneer welding or repair near Berne, In. has all kind of chain repairs can custom make slats for manure spreaders. Never taken T' type chains apart.
BigGuy1000
Posted: 20 Dec 2018 at 11:13am |
No! do from on top. Loosen the chain tightners ALL the way, get inside with your fence stretcher extended all the way, hook on one chain, PULL PULL as much as you can, in the center of the stretcher hooks you will have enough slack to turn one link sideways so that you can get the top of the T thru its link!!!!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55281 |
Posted: 20 Dec 2018 at 6:30pm |
Easier to do from top, no stoopin, crawlin, and you won't get any sh!t in yer eye!
john(MI)
Posted: 20 Dec 2018 at 6:35pm |
If you got a loader, turn it on it's side and do it standing up! You can check out the undercarriage for decay that may need repair.
JimWenigOH
Posted: 20 Dec 2018 at 6:51pm |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 21 Dec 2018 at 7:44am |
"Stretch" is usually a little stretch maybe and a lot of wear and corrosion for sure. Wear and corrosion makes every moving pin smaller and hole bigger. Gain 1/16 of an inch clearance in a hole, every 16 links gives you 1 inch of slack.
