WD wide front end
wdtractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Topic: WD wide front end
    Posted: 13 Dec 2018 at 7:05pm
I have a 1952 WD with the narrow front end and I would like to change it to the wide front end, what do I need to know about and look for when I find one and also will my steering shaft still work on the wide front end. Thank Y'all for any information, it will be appreciated.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 9:13pm
Your steering shaft will work fine,disconnect at the u-joint.
You will need the complete front-end,this is the big heavy bolster,and axle,your front wheels will work...
Another option would be an aftermarket Swartz or norden(sp)?,, I think they can utilize the narrow front bolster
Edited by Michael V (NM) - 13 Dec 2018 at 9:13pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 10:46pm
Mine has an interchangeable front end on it. I can put single front, dual or wide front on in about 20 minutes. No messing with steering at all. It takes longer to jack up the tractor than to swap the front end. Maybe yours is that style?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 11:05pm
How could I tell if mine is interchangeable like yours
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 3:47am
Got pics of this interchangeable front? Sounds really neat.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 7:09am
The bolster will look like a wide front. Either a round cover on the top or a small bolt on plate on the top.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 8:26am
If it has a narrow front on it and it has the mounting holes for the wide front plate you have a convertible frontend. Standard narrow fronts don't have the wide front mounting boss.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 8:32am
Here you go. I can't find a shot of the interchangeable narrow front end.
Edited by Don(MO) - 14 Dec 2018 at 4:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 9:51pm
The picture of my WD won't load,but on top of the bolster there is a flat plate with 4 bolts is this the interchangeable front end that you're talking about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 9:56pm
That single front wheel is really neat Don -- how rare were those?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 10:31pm
If you have a four bolt cover then your front end is the  Std. Dual Front, if it had a six bolt cover or the later round cover then it has the changeable front bolster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 10:33pm
I don't think of them as rare just harder to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 11:24pm
Can I still change it to the wide front end
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 6:19am
Yes, you can still change over to a wide front end. Your entire front support comes out from under the radiator and the wide front goes back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 7:45am
Thank you all for all the information
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 12:45pm
I leave the single front on mine and the other 2 are out back.
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 4:10pm
Some tips for when you change it:
1. There are four bolts through the frame on each side. They have probably been in there for 60+ years, so they usually come out hard, or break off. Hit them with a big fancy hammer  (BFH) several times before you even try to get them out. If they don't turn quite easily (and chances are they won't), get your torch out. It's MUCH easier to take your time getting them out than it is to try to remove the broken pieces after you put break them off.
2. There are two bolts in the back that hold the steering shaft in the bolster. I have found it is easier to remove those two bolts and remove the steering shaft, than it is to try to get the universal joint apart. It is a good time to look the universal joint over and replace it if it is bad (I find many are bad).
3. Make sure the tractor is blocked securely, because chances are good you are going to have to do a lot of pushing, pulling and pounding on it to get the old front end out.
4. After you get all the bolts out, remove all the bolts on the left side of the tractor frame. I find it is much quicker and easier to get the old bolster out with the frame rails separated with the frame loosened and spread apart. I loosen the left side so I don't have to fool with the belt pulley on the right side.
5. Before I install the bolster on the front end that I am installing, I put anti-seize on the sides of the bolster and all the bolts. Chances are good that it will never be changed again, but I always put the anti-seize on in case it's me that has to change it.
6. After you get it changed, retorque the bolts several times. They will loosen!
I hope this helps!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2018 at 7:30pm
Gives me an idea of what I am up against!---Gotta change one on 45! thanks; ac fleet
