FTB25-24 Forklift Help
Power Wagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Wagon Quote  Post ReplyReply Direct Link To This Post Topic: FTB25-24 Forklift Help
    Posted: 06 Dec 2018 at 9:48pm
I was recently "gifted" a Type G, FTB25-24-PS forklift that a renter left behind.
Serial # is 65032000, so what year is it???
Looking for a parts book and manual for it if available somewhere??
Previous owner said it was coughing and backfiring, so they put in some Tune Up parts (points, condenser, rotor, cap, plugs & wires). That didn’t fix it, so they took the head off to make sure all the valves were moving OK. It all looked good, so they put it back on, played with the propane vaporizer, but just sort of gave up on it before they moved out. It runs a LOT better since I put the plug wires on in the proper firing order, and turned the Bar-B-Q propane tank upside down so it draws liquid.  Everything seems to work, but it has a horrible knock in it somewhere. It even knocks turning over on the starter. It makes the most noise when running the tilt cylinders, so I am thinking the knock might be something loose in the drive/hydraulic system, rather than the engine? Would really like to see a parts breakdown of what could be loose in the transmission before I start to take things apart. Any information or experience with one of these would be appreciated.
Thanks
Edited by Power Wagon - 06 Dec 2018 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Wagon Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 9:50pm
Cut and paste didn't work in the proper color, so jut highlight the post above to see it
RonnieJones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonnieJones Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 10:10pm
Here you go I always paste in notepad first then copy it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonnieJones Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 10:15pm
This is coming from car experience and I honestly have no idea about this. On GM's 3.8L's the harmonic balancer would go bad and make a terrible racket much like you describe. Flywheels and loose torque converter bolts make a aweful sound to. Other than that I am of no use sorry.
