Repairing ferds today |
HD6GTOM
Topic: Repairing ferds todayPosted: 05 Dec 2018 at 7:02pm |
Grandson calls me last night. 2010 ferd fusion won't start in the highschool parking lot. 40 mile drive one way, starter is shot. Ordered a starter last night, over $200.00 for a rebuilt unit. Went back this AM with starter, gotta remove a pile of stuff just to see the starter. Got everything off but the back bolt. Found out ya gotta drop the back of the motor 2-3" to get to the back bolt. Can't drag it to the shop, tranny won't stand it. Now Gotta call the tow truck, $100.00 to haul the darn thing to the shop, And that was a back haul for the roll back driver. Boys at the shop outta get to it tomorrow or the next day. I no sooner get home and daughter in law calls again, says the 2010 f150 is now having problems. At least its at her house. Back I went, unhooked the battery so it won't burn up. Probably be another $100.00 haul bill. Son is in Afganastan. I don't mind helping him, but gosh darn it, I told him not to buy these 2 units. I did talk to son today so he is aware of the car being broke, I have no idea about this darn pickup. Tony the shop forman is a ferd fanatic, he'll figure it out. Sure cuts into my nap time though
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25259 |
Posted: 05 Dec 2018 at 7:27pm |
friend has an Escape..died..needs alternator.. that's a 3 hour ORDEAL UNDER the car...probably a $200 alternator, $300 shop time...told him to scrap the car as it ain't worth $500. $100 for the 40 mile tow is CHEAP ! In town here they get $100. I found out most 'yard tree' and some 'pro' mechanics do NOT reinstall the 3rd bolt on Ford starters as it's a real PITA to do,though IF you have a 3' extension, U-jointy thing and glue the bolt on it can be done ! It ain't just Fords of course ..all have problems... Wife's 99 CRV, ONE owner, her, doors won't lock cause the 25 wire cable in the driver's door is 1/2" too short ! The 'solution' ? REMOVE the door, cut and splice 2" of wire to ALL 25 wires,heatshink, reattach door. Maybe the 'contractor' will do that as hid daughter's getting the car next year. Maybe AFTER he fixes the leaky exhuast he installed. Maybe AFTER the garage roof gets done ?? Kinda sad I can get that into any message ! Jay
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 05 Dec 2018 at 8:16pm |
Jaybmiller, I was told back around 1970 that a good ferd mechanic never installs the back bolt on their 3 bolt starters
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 06 Dec 2018 at 9:24am |
The starter on my 2006 HHR is same way. I had to use three 6" extensions plus a wobble joint to remove the one next to the block,,,!! Lots and lots of GM cussin went on,,,and,,,and,,I done the next guy a huge favor and threw thet bolt in my bolt bin!!! For years and years, the Chevy V8 starters were held on with only 2 bolts and now the little old 4 cylinders gotta have 3 bolts,,,?? Not at this mechanic's shop.!! PFFTTtttt
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 06 Dec 2018 at 9:45am |
HD and Jayb you two sure have been having your share? What's you guys been doing???
Edited by chaskaduo - 06 Dec 2018 at 9:45am |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 06 Dec 2018 at 10:54am |
They done pizzed off the big Guy upstairs I think.
Oh,,,,,,,,,,,and as Shameless would say,,,,,,,,,,,they gots' Ferds.... |
chaskaduo
Posted: 06 Dec 2018 at 11:27am |
But how did they pizz off the big guy as I do not want to repeat it?
Edited by chaskaduo - 06 Dec 2018 at 11:28am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 06 Dec 2018 at 11:34am |
Well chas, as they say, the lord works in mysterious ways!
fixer1958
Posted: 06 Dec 2018 at 6:37pm |
I hate it when it interferes with nap time. Everyone else knows it too. |
HD6GTOM
Posted: 06 Dec 2018 at 7:29pm |
This dad ratted starter only has 2 bolts holding it on. There is no way I can find to get to this back bolt. Boys at the car dealership I used to work for are gonna drop the motor and install this starter. They Should have it done by the weekend. $100.00 tow bill was a back haul for the tow truck driver or it would have been a lot more.
shameless dude
Posted: 07 Dec 2018 at 9:34am |
I don't need to say nuthin! (poke,poke)
fixer1958
Posted: 07 Dec 2018 at 9:57am |
I just looked up the starter on a 2010 Ford Fusion. 4 different engine options. 2 V6's, 2- 4 cyl's. On any of them it has 2 bolts and the labor guide calls for less than an hour on any of them. Why would you have to drop the engine? Labor guides can be deceiving especially on a Ferd but still. If it call for less than an hour it should practically fall on its own after you get the BS out of the way. |
Ted J
Posted: 07 Dec 2018 at 8:31pm |
HD6GTOM
Posted: 07 Dec 2018 at 9:05pm |
V6 motor. There is no way to get my hand, or the pro mechanics hand that closed up his shop for a half hour to help me, back there to get the nuts off. You gotta drop the motor down to get to that darn bolt. If you had it up on a hoist, with air guns, dropped it down, you could probably do it in an hour. You can't do it in a parking lot. Why did ferd double nut the consarned thing.
Edited by HD6GTOM - 07 Dec 2018 at 9:06pm |
jaybmiller
Posted: 08 Dec 2018 at 6:28am |
OK.. EVERY manufacturer ONLY does 'stuff' that allows them to build faster. They really don't care,after all you WILL take it back to the shop for repairs and pay the price. Seems most everyone has 4wd,4dr PUs as the family ride and since they cost 60K+, you'll pay the 1-2K to fix it right ?? Man, it's been a GREAT marketing scam....get the public to buy more than they need at a price far greater than it's worth AND keep you coming back for service... That being said, the bodywork on my 97 F150 is done,just need to 'rockerguard' the underside of the box and I'm good to go. I've 'budgetted' 1K per year for my mechanic to 'upkeep' on the truck which is 2-3 payments on a new ride. Truck has just less than 80,000 miles on, everything works so I'm happy. Jay
fixer1958
Posted: 08 Dec 2018 at 6:38am |
I have been saying for a long time that I'm glad I don't have to take my vehicles to a shop because I couldn't afford myself. Out shop rate is $132. Very busy all the time. It will probably go up again first of the year.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35684 |
Posted: 08 Dec 2018 at 6:57am |
Pretty sad these days as I was a mechanic in the 70s/80s/90s and saw shop rates ramp up from $18/hr to when I left at $65/hr wages moved from $5/hr to over $20. Flat rates schedules went from reasonable to sub zero tolerance where the mechanics could barely break even on times most time NOT making time on repairs where so many if not all TOO many left the business. Still have some great shops with good guys, still struggling along but are almost NOT making a decent living with tooling changes, special tooling requirements, all makes and models changes so often with re-training to compete eating away at tight enough margins.
$132/hr rate sounds bad as a consumer but then look from the other side as to that tooling, electronics diagnostics equipment, utilities expenses with the added Environmental charges, mechanics pay and whatever benefits are used to keep them in a shop, the tooling these poor guys HAVE to buy just to be able to access our high tech packed, mostly plastic, electronics loaded MASSIVELY varied makes and models machines and not damage them in repairing them. Sad days for the Mechanic trade. Edited by DMiller - 08 Dec 2018 at 6:57am |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 08 Dec 2018 at 1:05pm |
Everything you said is so true. I have gotten to using 2 different shops side by side,both of them very good with in there specialty. I just pay them and try not to think about how high it is cause I am sure I cannot get it cheaper anywhere else and not have them getting to me some other way. But I just looked $102 hour.
fixer1958
Posted: 08 Dec 2018 at 5:32pm |
The shop labor rate is not out of line for the area. Actually cheaper than a few other shops, dealer or otherwise. Got one really sharp young guy I work with that I am trying to help get a handle on stuff. He's doing really well. Went to school for this and is about 40k in hock in student loans. Cost him $650 a month to work there....tool bills, education etc. He is starting to see money in the black now. |
jaybmiller
Posted: 08 Dec 2018 at 6:28pm |
$132 USD per hr is $175 Canucks, here north of the 49th ! That's waay too much . speclayy iwhen they replace 4 things to fix a problem AND charge for the 3 GOOD things that didn't need replacing! Avg here is tad over $100 Cdn. 100 I'll pay as I can't easily crawl or see stuff that needs to be done but if it was 175, well, I'd be buy the 85 ElCamino next door and drive that. CHEAP and EASY to fix. Yes, I understand the education and tools and that but I never got more than $20/hr design/build/fix fancy microcomputer energy control systems or other 'high tech' gizmos. Heck I used to make $60 hr plowing snow in 1976.... Jay
desertjoe
Posted: 08 Dec 2018 at 8:17pm |
The flat rate in this area just went to $162/hr,,,,yep,,,,$162 bucks an hour,,,,,,!! BUT,,,what this does for the customer is you KNOW up front how much the repair is gonna cost you as if you ask the dealer HOW MUCH,,, the dealer can tell you how many hours the technician can flag for the repair,,,and that's all. A reputable dealer will not allow a repairman to keep throwing parts at a job til he finally gets it running. If the technician can't get it done within this flat rate,,it's on him. With the HI-Tech computors now in the cars,,they can anylize the problem to a tee.
HD6GTOM
Posted: 09 Dec 2018 at 12:23am |
This is at the car dealership I used to work for. They have been known to forget to charge me for labor. I seriously doubt they will forget to this time, since the dam motor has to come down.
