Cab interior kits for 8000 series |
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Topic: Cab interior kits for 8000 seriesPosted: 05 Dec 2018 at 3:22pm |
Comments, source and price for cab kit for Allis 8000 cab.
Also the deluxe brown plaid seat cover. The cab kits from Shoup would these be Fehr? Has anyone used Shoup cab kits and how did they fit and look.
Edited by WD45 - 05 Dec 2018 at 7:46pm |
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1164 |
Posted: 05 Dec 2018 at 7:14pm |
Fehr cab interiors is where I've purchased 2 kits from, roughly $500 will do top and bottom. Highly recommend them. Kits are close to perfect match except the posts where a little big on the two I purchased from them. They also include glue which is very strong in bonding. Their window seal kit is a dead on match too. As for seat cloth, good luck. I haven't been able to find a textile place to reproduce it. It someone knew of a place to get it reproduced, I would gladly send a old cover to them to get the pattern copied.
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7540 |
Posted: 05 Dec 2018 at 8:35pm |
Ivan Summerix in Michigan is supposed to have seat covers that are very close to original. I must also give a thumbs up to the Fehr cab kits. Finished putting one in my 6080 a few months ago. Very good quality!
Unit3
Posted: 05 Dec 2018 at 9:15pm |
Try Hy-Capacity out of Humboldt, Iowa. I have used them in both of the 8070's. Drill out the rivets in the two strips at the right side up high at the door and rear side window and the headliner will come down easier. When installing the foam, I dry fit things first. I started at the bottom and worked my way up. In dad's 8050, the owner before us started at the top and went down. The two pieces on the post were stuffed together and it looks bad. If they would have started with the large fender piece, then the small piece on the post, anything extra on the post could have been tucked up under the headliner and the fit would have been perfect. Hope this helps.
Steve Bright
Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
Posted: 09 Dec 2023 at 9:04pm |
Where do you get the straps to pull the doors shut?
Kenny L.
Posted: 09 Dec 2023 at 9:41pm |
I use Hi Capacity for the upper part and a Ferh floor mat on my 8030.
Kenny L.
Posted: 09 Dec 2023 at 9:44pm |
Steve I found my at a salvage yard, take a drill and drill bits make it a lot easier to remove them.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 649 |
Posted: 09 Dec 2023 at 10:07pm |
The pull strap on a 73-87 chevy pickup is a decent replacement. It would need to be cut but they could be made to work
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3582 |
Posted: 10 Dec 2023 at 7:33am |
WD45, Here’s a March 2021 link to PaFarmer’s 8070 restoration. Similar discussions & ideas in it.
https://www.allischalmers.com/forum/8070-restoration_topic179118_page1.html Edited by AC7060IL - 10 Dec 2023 at 7:35am |
