37 A Tire sizes (New Tires)
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Topic: 37 A Tire sizes (New Tires)
    Posted: 02 Dec 2018 at 7:39pm
I recently bought a 37 A that needs all 4 tires. I was just wondering what size tires others have on their A??  I was thinking of going with 14.9 28 on the rear and 7.50 18 on the front. Thanks
Edited by ZachD89 - 15 Jan 2019 at 5:57pm
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 8:31pm
Widen the back rims for 18.4x28 widen them on the outside works best. I really like mine at that size. The 7.50 are fine on the front sets level with this set up
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 9:08pm
Dave is right on with the rear tires, they came with 14-28 tires which converts to 16.9-28.  I've had both, 14.9 and 16.9-28 on mine, I really like the looks of the 16.9 over the 14.9, I ordered new rims with the offset to the outside also.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 7:33am
15 28 wards on mine but that may be a little hard to find. Same as 16.9. If you widen do as said or they will hit the belt pully
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 5:38pm
I have 16.9 on one and the old 15’s on the other one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 6:08pm
Mine has 11 inch rims so the 16.9 would probably be way to wide
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 9:18am
How much work or money do you want to spend? My opinion is As look like crap on OEM sized tires and even worse on the modern replacements for that OEM size, but thats me If you want to keep the OEM rims and not spend much for tires your stuck with 14.9-28s and tires that are all sucked in at the the beads and look like they belong on a 25HP tractor. Or you can widen the rims a little bit and up size to 16.9 and the tires are still too small for a good looking outfit (in my slightly opinionated opinion)  The only way to make an A look right is on the old 15-28 tire which is 18.4-28 today.  The pic is of my A on  old 15-28s with about 4" put in the rims.  A modern 18.4-28 requires a LOT more in the rims to get same look as different tire construction requires different rim width.  18.4- 28s are also very hard to find.  Another option is to go with 18.4-30 and weld a spacer to the drop center so it fits the wheel. They look real nice on a A.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2018 at 11:03am
18.4 28 or the thirties like Butch said make the A look like a real tractor in my opinion. I have 18.4 28 on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2018 at 8:16pm
Here's the A with 14.9's, same tractor with 16.9's.  The 14.9's fit in the furrow better but I just couldn't stand the look, it deserved the bigger footprint!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2018 at 8:50pm
I.M.H.O. The A with the wider tires look like the D21's Great Grandad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2018 at 9:17pm
Thanks for the replies everyone. I like the 16.9's a lot better than the 14.9's so I will be ordering 15inch rims and getting 16.9 tires. I will post pictures when I have the new tires on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2018 at 5:24pm
Here is a picture of my A before it gets the new tires mounted.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2018 at 7:32am
Not a bad looking A to start out with .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 5:56pm
Here are pictures of my A with the new rims and tires. The 16.9 tires turned out good and looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 6:34pm
Looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 6:23pm
Thanks
This page was generated in 0.266 seconds.
