Will it pull it???
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Topic: Will it pull it???
    Posted: 01 Dec 2018 at 3:06pm
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 3:10pm
You bet. If not ,by a performance chip. lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 3:18pm
Sure she'll pull it but stopping it with the hand brakes may pose a challenge . . . .
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 3:19pm
NO fear if that is empty and on the flat...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 6:50pm
It has a Gleaner E engine, M code, in it. Maybe a beacon will help too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 6:53pm
Sure it will pull it all day long just don't even think about filling it.LOL Tom
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 9:22pm
If it's on flat concrete and the tires are fully inflated you could pull it with a garden tractor.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 10:18pm
At first I was going to say no, but then I saw you have a 12v alt. If you can power the tail lights, drop in a hitch pin, hook the safety chain, grab a hand full of throttle and dump the clutch. A 6" flame will appear from the stack as the radiator cap rises skyward. Good luck. God speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 6:02am
OK guys...kinda curious... just how much would it weigh filled with grain ?
I'm thinkin g'going' isn't the problem... STOPPING is !
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 6:50am
500 bu. corn @ 56 lbs. per bushel = 28,000 lbs. plus wagon 3000 ( guessing) = 31,000 lbs. Might need fluid in the tires.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 7:11am
I've moved loaded 550 bu wagons around a gravel yard with a WD that had fluid in the tires.  Did some spinning to get started.  Truck tires on the wagon help a bunch.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 8:12am
thanks for the numbers !! Yeesh that WOULD be quite a load to get moving and it'd never stop too quick !!
Jay
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 9:24am
I think the wagon weighs closer to 6000. I was thinking about buying one before harvest.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 10:26am
Wagon is just shy of 5900#.
Edited by bigal121892 - 02 Dec 2018 at 10:27am
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 10:32am
But if you put fluid in all four tires.
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 8:28pm
Gee you people of no faith,Wink sure it will stop somewhere.  You just may not like where. LOL Or has gravity gone the way of climateWink, and had a change.
dano-59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dano-59 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 9:08pm
looks dangerous!!! Had a co-worker loose his life in a under size tractor without ROPS an a half loaded grain cart .Tractor spun out on an incline ,drug him backwards, tractor jackknifed and overturned
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 11:59pm
should pull it the same as if i'd hooked my Buick hearse on it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 9:44am
Is that a dead on pull Shameless?
Edited by chaskaduo - 03 Dec 2018 at 10:05am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 9:52am
Heck yeah it'll pull it.  To where you fill it!
dano-59's story reminds me....I'm sure this thread is meant in jest, but still.  2 years ago I was spreading lime.  The spreader was the design where PTO operates the live bottom as well as the slingers, so to get the correct rate, you have to drive a given ground speed.  I was using a tractor that "would pull it".....I gave my sphincter quite a work out when I came to the end, the slight side hill and other conditions were "just right" and when I began the turn that thing shoved the ass end of the tractor straight and began to jack knife it in a hurry.  If I hadn't been leery of what could happen, might not be typing here right now, taking my meals through a straw and unable to wave buh-bye.
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2018 at 6:01pm
There are worse ways to die I guess.😉
