615 (D15 SII), engine knock?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: 615 (D15 SII), engine knock?
    Posted: 29 Nov 2018 at 7:12pm
My 615 has the same gas engine found in the D15 SII (160 ci).  At idle, it has a loud knocking noise coming from the rear, top of the engine.  Using a screwdriver as a listening device, the noise seems to be originating from the top region of the head at the rear of the engine, right about where the valves are on the exhaust side.  I adjusted the valves while the engine was warm, but the noise still persists.  As the idle increases, the knocking is less noticeable, and cannot be heard at 1/3 to full throttle.  But it may be the other engine noise is drowning it out.
I do know that someone tried to pull start the tractor while it was hydrolocked, but have no idea if that may be the cause or do to the shuttle clutch, the engine may not have even turned over.
Any idea what the knocking noise could be?
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 9:10pm
We had a d17 with a stiff wrist pin. It made a knocking noise like you describe when the piston skirts slapped against the sleeve. Could be the connecting rod is bent causing the same issue
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 10:47am
IGNITION TIMING BEING OFF WILL CAUSE A IGNITION KNOCK IN THE TOP END
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
This page was generated in 0.057 seconds.
