B & C tread width |
Richmar
Topic: B & C tread widthPosted: 29 Nov 2018 at 11:36am |
B tread width question Are all B rear tread widths the same or are the last B's tread width same as the C's Richmar |
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 29 Nov 2018 at 12:19pm |
Richmar, With my father we sold the B for the life of the unit. As to tread width's the basic one row B's are the same. Yes, you can jiggle the wheels a bit by moving the wheels from side to side and setting the front wheels inside out but that is it. However, there was a wide front B which had the dished rear wheels and the adjustable front axle. You can easily recognize them with the dished rear wheels or the adjustable front axle. The C was the B made for two row operation so the rear is wider and the standard C has a narrow front. They did make a single wheel C and a wide front C. The C rear wheels could be adjusted to the B width but the dished rear would make them wider. If you have a B take good care of my favorite. Good Luck! Bill Long
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 29 Nov 2018 at 1:05pm |
Bill i have a sales book on your little B .Two B's mowing on front.Treads standard 40 1/2 to 52 1/2, adj axle 40 to 68.Have old spec sheet on old B and C.C tread was 52 to 80 .I have a 49 B i custemized, you may have seen it on these pages.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 29 Nov 2018 at 1:54pm |
At TractorData.com, the B dimensions page lists rear tread as 40 to 52 inches, and 40 to 60 inches. Does not note anything on either dimensions. |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 29 Nov 2018 at 2:21pm |
Are you referring to the distance between the wheels, or the rim width and tire size? They could be had with rims for 7, 7.50, 8, 9, and 10" tires with 9 and 10 being available and seemingly the only options starting at B18055 and I would assume all C's. AaronSEIA
chaskaduo
Posted: 29 Nov 2018 at 2:31pm |
Good point Aaron, and B18055 would be 1939.
txtractorguy
Posted: 29 Nov 2018 at 2:37pm |
This may not be what you are looking for, but I'll submit and hope you find it helpful.
Rear Tires: 7x24, 7.5x24, 9x24 prior to tractor B-18055, 8x24, 9x24 or 10x 24 for B-18055 and up. Front Tires: 4x15 standard, 6x16 special. |
wfmurray
Posted: 29 Nov 2018 at 2:55pm |
Tread width is measured from center to center of tire.
Richmar
Posted: 29 Nov 2018 at 3:20pm |
What I wanted to know ,were the final drive housing the same on all B's even the last ones built. I know the rear wheels were different, on the later B's they were same as the C's . Did they keep the final drives the same even though the wheels changed .
Richmar |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 29 Nov 2018 at 4:51pm |
NO: Some of the final drives on the very late Bs has a flange axle like the C tractors to do away with the splined hubs.
The Build a B project tractor that I have has this style flange axles. The earlier B that had the 5 bolt hubs still had the splined axle with a 5 bolt hub. Edited by PaulB - 29 Nov 2018 at 4:52pm |
chaskaduo
Posted: 29 Nov 2018 at 5:59pm |
From the AGCO ALLIS PARTS BOOK page 144 Edited by chaskaduo - 29 Nov 2018 at 6:01pm |
AaronSEIA
Posted: 30 Nov 2018 at 3:58pm |
From the parts book it looks like there was only 1 final drive casting. It looks like at B #18055 they changed to the 5 bolt flanged axle. AaronSEIA
