Chisel on 100 hp tractor
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: Chisel on 100 hp tractor
    Posted: 28 Nov 2018 at 2:45pm
How big chisel will a 8010 allis or 7000 handle comfortably? Thinking buying a chisel but not sure what width or if tractor can handle one? What brands and models do you all prefer?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 3:01pm
Depends on soil and what type of plow, how deep and how heavy the plow is. I pull a 9 shank old MM (a rebadged Krause) 9" deep with the 190XT. The shanks are 12" on center and have 3" twisted shovels. The 9 shank Min-Til 1500 can stop my 7050 and cause it to spin out. It has the shanks at 15" on center and 3" shovels at about 10" depth and straight disk blades in front. Last year I took 4 shanks off and run 30" on center for the 1500 and 12" deep or maybe deeper, not sure how deep it exactly goes.
Edited by Lonn - 28 Nov 2018 at 3:02pm
Wink
I am a Russian Bot
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 4:02pm
I had a 10ft-9shank on a 7000.   There is a lot to figuring out what/where.  that is where i would start; then you can adjust the amount of shacks to what u wanna do.   at the end, i had 2 shanks that ran between the rows and left the corn stubble standing.   mine had hydralic wheels to set the depth.  I went to a 3 shank ripper, that fit my needs much better then the chisel!
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 6:25pm
Think the saying is 10hp per shank if just a chisel 15hp for disk chisel
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 7:45pm
Better have 20 HP per tooth in my area with the red clay if you want to pull a chisel plow like it should be pulled.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 7:54pm
Drats !,I was hoping a disc chisel would pull easier/shank due to the straight discs loosening the ground.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 8:18pm
Dad pulled a 12' 12 shank Brady, with a JD 4020 with duals, and M&W turbo. An 8010 or 7000 should be able to handle one as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 9:17pm
9 shanks on a 7050 and that is all I need. If I want to pull it like a field cultivator, it would more.      MACK
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 10:01pm
For a 7000/8010 I would say a 5 shank would fit well. I pull a 7 shank Allis Chalmers 1500 min till with my 7020, but I'm not going very deep and I know it's making her work. Finally found a 7045 so I don't need to work the 7020 as hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 11:05pm
I bought a 5 shank deep "V" sub soiler on an auction, took off the outter shanks on each side so I had 3 left, I dropped it in a couple foot, I went diagonal of the rows in the field. that was with my 7010, it didn't pull the chit out of the tractor but it let me know something was back there.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 3:22am
I have a 9 shank I pull behind my 200. It is a pull type unit. It is a Bush Hog brand. I do not have any front weights and the front is very light. I don't have any problem pulling it but you sure know it is there.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 6:53am
That's what I've always heard and it holds true thinking about how we chistle.
The disk chisels we run a 9 on the 150 HP tractor and an 11 on the 200 HP FWA. You can't pull the 11 shank with the FWA turned off.
Used to pull an 11 shank 3pt with the JD 4020 and it was a little too much for it. The 120HP tractor later was a good match.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 7:00am
I pulled a Bush Hog 12 shank chisel (12" on center & 3" twisted) with the 7050 and it was a breeze for it. Sunk it in all  the way. I thought the 9 shank 1500 was going to be a breeze too. Boy was I wrong!
Wink
I am a Russian Bot
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 7:06am
On the land I farm when in the good dirt my XT will roll on with a 7 shank but in the red clay (which I have a lot of) it is all it wants and then some
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 8:02am
I never had a disc chisel, any drawbar hooked equipment will need a heavier tractor and because there is no draft control may go deeper and need more power. I have used a 10 shank 3 bar,3 pt 3 inch twisted on a 7000 with duels but it would dino 128 pto . I now have a 2 bar 9 shank 3 pt with chisel points and it works well here on the 8010 or 210. If your in corn ground that is different.if mounted you'll need a 3 bar plow. I never worried a lot about the clay banks, not gonna produce anyway. Subsoil and move on. If I went to buy a disc chisel for the 8010 it would probably be a 5 shank, but don't see that in my future. Have you looked at offset disc, I use it more with a subsoiler than I do the chisel. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 3:06pm
This is all good info thank you all for your help
ozarkfarmer01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ozarkfarmer01 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 10:19pm
If you decide to proceed with a chisel plow I have a Mohawk 1100 with eleven shanks that is for sale. It's a 3 point model with gauge wheels. Needs points.
We pulled it with a 4020, then 4230 in sandy loam river bottom soil.
I'm located in north central Arkansas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 6:02am
OK, please educate me, why do you pull HUGE chisels like that ? Is it to breakup the soil cause it's really 'tight' or hard ??
I have an A-C subsoiler,goes down  2 feet, but wife's garden is real loamy. Those chisels only go down 9-10" , so I'm curious.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 7:11am
Chisel are a tillage tool, less evasive than a moldboard and leave some residue on top for some erosion control. They are not for breaking up a hard pan. Normaly can pull a wider chisel than you can a moldboard plow thus cover more ground faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 7:28am
Actually breaking up the subsoil/hard pan is why I use a chisel plow,I shoot for around
16" deep opens up the ground for water to go in and for roots of plants to be able to penetrate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 8:56am
Thanks for the info guys !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 6:07pm
Guys I want say thanks for your help. I decided to just pull the 4 bottom plow. I have a Rome offset disc but wanted to break it up deeper. So plowing it is.
This page was generated in 0.120 seconds.
