Speaking of turbo matches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: Speaking of turbo matches?
    Posted: 27 Nov 2018 at 2:02pm
What would most think would be a good choice for a Holset on a 330 CID running an A pump no RPM limit (although I'm thinking about 5500-6000) with cam work done. this will be for a 4500-7500 pound tractor.  I currently have a few Holsets around from different 5.9 Cummins and curious if any of them might be what I'm looking for.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 5:10am
Running an inter cooler and open RPM? InSpin a 2.6 HX 50 in 6500 with 301ci I think that would be a pretty good mate
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 5:01pm
What kind of boost pressure are you getting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 4:46am
Around 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 4:28pm
That's about what I was hoping to get. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 5:00pm
Are you running an intercooler? And how many cc of fuel are you running?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 4:12pm
According to my pump guy,  the A pump will easily go into the 400cc range and could go more. I want to use an icewater intercooler if I can find something that will work under the hood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 4:44pm
With out doing a ton of work and money spent you can get 470cc a pump guy could say better. But with an inter cooler your going to need at least 500. On my person I’m running 525cc with a 2.6 hx50 Charger. Getting that to fit in stock location with stock 190 manifold well I would like to see pictures if you do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2018 at 5:33pm
Bulge the hood !!! Looks so cool
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2018 at 4:55am
Won't be what anyone is expecting form me. I want it to be a sleeper. This will be a European tractor.
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2018 at 7:54pm
I have an adapter plate , to put a 426 intercooler that has been adapted with hi flow ice water through it ! Works great
This page was generated in 0.434 seconds.
